Question about Saeco VIA Venezia
Great coffee now tasts bitter- left it on all night
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: coffee stays in brewer and is wet coffee tastes
Try to clean the showers both upper and lower on the removable coffee group. If they are blocked from dry coffee then you have the result you describe. If not then you presure pump my not pump properly or you have a lot of scale that blocked the water flow.
Also check the water if it hot enoght since if the thermostat can stop before the water heat up to 95 C and if it is cold we can have the result you have mention.
Good luck.
Remeber to vote for this answer.
Posted on Feb 25, 2010
Coffee tastes bitter
two days is not enough for the machine to scale or get dirty from old grinds usually would be either coffee or water problem ---but depending on machine you have didnt specify- can be residue from plastic or container try running a vinegar cleanse than 3 just fresh water then try a coffee drop and see it taste is any different if no change bring back for a refund or exchange
Aug 29, 2016 | Coffee Makers & Espresso Machines
How can I avoid bitter coffee?
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
Espresso Machines Coffee Makers Grinders Reviews
Sep 08, 2014 | Coffee Makers & Espresso Machines
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Over time, my coffee has become acrid and bitter. I use fresh ground coffee and clean my pot regularly...what else should I do?
There may be some buildup in the machine other than in the pot itself. To test this, try running the brew cycle with no beans. Taste the hot water. If it's acrid and bitter, your problem lies in buildup (such as the basket). Otherwise, if the hot water just tastes like hot water, then the temperature of the water has probably become too high (that will make coffee tastes more bitter). If this is the problem, there's probably no fix (just make sure you fill the reservoir with cold, not hot, water).
Sep 26, 2013 | Bunn Pour-O-Matic VPR
Why are some coffee's more bitter than others?
There are several factors resulting in a bitterer cup of coffee:
The bean - Robusta beans are more bitter than Arabica
Roasting - darker roasts are generally more bitter
Brewing method - espresso tends to taste more bitter
Feb 07, 2013 | Wine & Spirits
Why is coffee bitter?
Bitterness is a dominant quality in the overall taste of coffee. You need a certain amount of bitterness to balance out the flavor. There are two types of chemicals that give coffee most of its bitter taste - both are antioxidants.
Jan 10, 2013 | Wine & Spirits
Coffee has a bitter, plastic, toxic taste. Even after cleaning and running many cups through new machine
Debris was left in the chamber when manufacturing the unit. Flus and clean accordingly and it will survice.
Dec 27, 2011 | Keurig Special Edition B60 Coffee Maker
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Apr 05, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee is really bitter and doens't taste good
hmm well it wouldn't surprise me. I'm glad you were able to get to the bottom of it! ;) have a great day and enjoy your Keurig!
May 26, 2010 | Keurig B60 Coffee Maker
BITTER TASTING COFFEE
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
Mar 13, 2010 | Rancilio Coffee Makers & Espresso Machines
Saeco VIA Venezia Logo
20 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
