Question about Sceptre X42GV-Komodo 42 in. LCD TV
Sceptre 32 led - Sceptre X42GV-Komodo 42 in. LCD TV
Dark screen more so in the center
Sounds like the LED's are not getting enough power. The power board must be going bad.
May 29, 2015 | Sceptre X322BV HD 32 inch Class Television...
How do i change the region code on a Sceptre E32 HDTV
Look it up in your user's manual. If you don't have one, get it from this link
http://www.sceptre.com/pub/Manuals/LED/E325BD-HD-12222011.pdf
Also you can contact Sceptre
Welcome to Sceptre Inc
May 12, 2015 | Sceptre Televison & Video
Sceptre tv troubleshooting
IT could be because your signal is poor and that will cause the problem, re align your antenna or buy a better one
Aug 29, 2014 | Sceptre 32" Class LED 720p 60Hz HDTV2.35"...
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre tv, no sound no picture
In other-words it is dead. Check its main power regulator board. Replace it.
Jan 09, 2013 | Sceptre 32 X320BVHD 32 LCD TV
My Sceptre X32GV-Komodo got a problem recently: I heard a little sound like "PA" then the screen turned to black while I was using VGA to watch movie from a PC, the Power LED was still Blue. Later, I...
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at tech@ccl-la.com.
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 17, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Nov 30, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
32" Sceptre LCD No POwer
0939a31.jpg This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me pbj0327@yahoo.com.
Thanks! and good luck m007!
Nov 28, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X42GV-Komodo 42 in. LCD TV Logo
12 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
