Question about Nokia 6300 Cellular Phone
Memory card not reconzing
My mobile was kept in bag n my bag got wet...i removed battery n waited for 2 hrs so it is almost dried...then i inserted the battery. n switched on the mobile...in gallery option i cant find memory card folder...means my phone is not reconzing memory card...what should i do???
  • 4,102 Answers
Their is nothing you can do as it has got wet it will have coroded the board sometimes if you are lucky it will dry out sounds like most of yours did dry out you can take the phone apart and buy some flux to clean the board with but this is hard to do as you need to be able to take the phone apart and make sure their is no static in your body cus this will deatroy the phone best thing to do is take it to phone shop tell them they will send it off to be cleaned for a fee but this should solve your problem some times they are beyond repair but you might be lucky it is the only thing you can do i dont advise taking the phone apart as you need special tools to do this and you need to make sure when you do it back up that you use a torque tool to tighten the screws up to the correct pressure but i advise you to take it to the shop to be done this should be cheaper then buying a new phone hope this is sopme help but their is not much you can do sorry
Posted on Oct 30, 2007
My nikon D3100 got wet from rain...what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
The Samsung GTC3300 mobile unit had dropped and wet. so the power does not ON and does not Charging.
Make sure that the battery was removed immediately and the phone kept for drying. Use some warm air blown to the battery compartment to dispel any moisture. Also you can pack the phone with some mositure absorbants like silica gel.
If you are able to open then remove and dry the board and ONLY when the boards are confirmed to be DRY you must insert the battery back. If there is function fault then you need help and consensus from a service center.
Aug 11, 2011 | Samsung GTC3300 Cell Phone
My flip got wet and wont turn on. is there anyway to save videos
Do you use memory cards with your camera? If so, the videos should be saved on the memory card. Just remove the card and download it to your pc or view it in another camera.
If you do not use memory cards, then remove the battery from the camera, put it in a bag of dry rice. close the top of the bag and leave the camera in that bag for about a week to dry it out all the way. Once it has dried out, it should work fine. But do not try and turn it on and off ect while part is still wet or you may loose your videos stored on it and/or damage the camera.
Jul 12, 2011 | Pure Digital Flip Mino Digital Camera
Samsung captivate got wet and now phone dosen't come on
Samsung captivate got wet and now phone dosen't turn on do not worry put out your sim card and memory card and battery put your mobile under table lamp 3 or 4 hours when the water is dry in your mobile put back battery sim and memory card back and turn it on i hope it work i think it is helpful to you please vote me thanks
Jun 28, 2011 | Cell Phones
Assalam o alaikum. my cell drop into water tommorrow next day working right.but now many of buttons are not working??? what i can do for this? Thanks
Number 1 rule if your phone gets wet... DO NOT turn it on.
Remove the battery from the phone. get a small ziploc freezer bag place phone in bag pour uncooked grains of rice into bag. Enough to cover phone completely. Close bag. Let it sit for at least 2 days.
This is to absorb all the moisture from the phone. Remove phone, insert battery and try using it. It may work. But you need to wait until your phone is completely dry before attempting to use it.
Mar 09, 2011 | Nokia 1208 Cellular Phone
Keep getting download message
You may still have water in tight places due to water surface tension. Open all the access doors, take out the SIM card, battery and anything else that is removable and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, saltine crackers and put them in the ziplock bag also and put on top of your microwave oven (if it is used a lot) or in the window where it gets direct sunlight. Leave it there until moisture gets on the bag then disappears again (3-5days) The dry items in the ziplock will help draw out all the moisture better than air drying. I have done this many times on cell phones, gameboys, etc. and it works everytime.
May 16, 2009 | Samsung Propel A767 Cell Phone
Samsung rant memory card problems.
hi there, it happens some time but dont panic
try these things
switch off mobile
take the battery and memory card out
wait for 2 min
put the things together
and turn the mobile phone on
it will work...
or
take the memory card out
put it in the sd card slot on your laptop or in external card reader
format the card
(when the format option comes selet 'FAT' not 'FAT32'
press ok
take the memory card out of the slot/reader
put it back
wait for a minute
turn the mobile on
and it will find the card
(but be sure the card inserts in a correct way.
hope it will help you.
Mar 24, 2009 | Samsung Rant Cell Phone
Insert SIM Card
you need to get a new main board.....or you can take it to a mobile store tech and have the phone fully service.
But the best solution would be to buy a need mobile....most time when a mobile gets wet......it's more of a 50/50 chance that it will work properly again.
Jan 06, 2008 | Motorola Mobility RAZR V3
Nokia 6300 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
