Question about Health & Beauty
Batricar countryman does anyone know how to rewire the push speed switch from 4 mph to 8 mph?
4 Suggested Answers
SOURCE: floor fan
try looking at http://www.ridgidforum.com/forum/archive/index.php/t-5702.html it helped me.
Posted on Jul 15, 2008
CarlGlas
  • 283 Answers
SOURCE: Hey I got an 88' Sportster 1200 4 speed, just changed the oil and the spark plugs, plugs gapped at .36, took it out for a ride, wasnt pushing it was going about 35-40 mph when she just stalled out
Check the plate that the points are connected to. Chances are it came lose. If that's not the problem, visit Clymner.com and order a workshop service repair manual.
Posted on Oct 08, 2012
ercupa190
  • 12223 Answers
SOURCE: I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Posted on Dec 18, 2012
Rpm to Mph chart, 2010 Chrysler t and c.
Thats gonna be tough since you would need to know exactly what gear the trans is in to figure speed based off rpm I would suggest just repairing the speedo or vehicle speed sensor which ever has failed
Jul 03, 2015 | Chrysler Cars & Trucks
2011 mini cooper countryman, starts, runs, drives but has low power.(50 mph ) max Due for service in 1200 miles.
The only way to correctly diagnose what is going on is to have a diagnostic scan done, sounds like the pcm has gone into 'limp home' mode which restricts power to prevent damage to the powertrain
Feb 15, 2015 | 2011 Mini Cooper Countryman
Had to disassemble a Hampton Bay ceiling fan to install a new light pull switch. Hung from a paperclip while fixing but it dropped and disconnected a number of wires. Rewired by my best guesses and now fan...
If you bought the switch from Lowes, most likely it's the wrong switch. Even if it looks the same on the outside, it could be different on the inside. As for the other wire, push it into the empty slot of the switch & see what happens. There has to be 4 wires in the switch. Black usually goes to L
Jan 04, 2015 | Hampton Bay Dryers
Batricar mobility scooter wiring instructions
Hi i have a batricar here, what you need to know ? , i cannot provide wiring info sadly... however i can give diagnostic info as i have repaired a large number of these, they now have a cult following pushing up prices...
Regards
Rob
www.facebook.com/gewizrepairs
Oct 29, 2014 | Health & Beauty
Mobility Scooter 8MPH ROAD OFF ROAD COUNTRYMAN BATRICAR
Hi, before i advise you is it possible to see a picture of the scooter in question ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 12, 2014 | Pride Go-Go Elite Traveller Plus HD...
I have a budda superdrive 30 II amp and have a setting question. I made a 2-12 cabinet to hook to this amp. Each speaker is 4 ohms. They are wired to their own output jack. My amp has 2 outputs for...
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
Apr 22, 2011 | Budda Superdrive 30 Series II Amp Combo
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Dont know how to use my 4wd
You first have the car running and as long as you are going or driving under the speed of 55 mph you can put it in 4 wheel drive high. for low come to a stop put in neatural and switch to low. put in drive and go. max speed 10 mph
Apr 20, 2009 | 1999 Isuzu Rodeo
Health & Beauty Logo
114 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
