Question about Frigidaire Dehumidifiers
BLOWER WHEEL BROKEN
Blower wheel blades have been broken, am looking for a replacement, model # LAD254NTL. Frigidaire does not list this part.
  • 2,237 Answers
Older model- might not be able to get a replacement. try appliancepartspros.com
Posted on Mar 01, 2014
4 Suggested Answers
  • 233 Answers
SOURCE: clicking when turn on... the blower wheel or Blade
if it is not under warranty , yes, if under warranty let your service provider do it and get the parts warrantied
Posted on Jul 13, 2009
  • 18 Answers
SOURCE: can a fix a cracked blower wheel for my dryer with
sorry to say dont do it if you were able to find that your very capable of replacing it good luck
Posted on Jul 19, 2009
  • 4736 Answers
SOURCE: My frigidaire dehumidifier mod. #LAD254NTL
Dave, this happens quite frequently. It''s due to a clog in the hose or a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie, slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Posted on Jun 27, 2011
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Feb 12, 2014 | Frigidaire Dehumidifiers
A quarter was found in the fan area and one of the blades is broken can i buy a replacement fan cover?
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=115442
Here is a short list of some replaceable parts for this unit. Which fan are you speaking of here?
Sep 23, 2011 | Maytag M7DH65B2A Dehumidifier
After 5 years of good operation, it now ices up immediately
If your Indoor Coil is Freezing Up,
You need see if the blower runs if it does, Then shut it off and check your filter, indoor coil and blower wheel, to see if they are dirty, if they are, they need to be cleaned, if not then you are probably low on refrigerant. If the blower doesn’t run when you turn the switch to on then you need to check the blower and capacitor out.
If your not familiar with any of this then you need to call a service tech.
Sep 08, 2009 | Maytag M7DH45B2A Dehumidifier
Ice is forming on the coils - delonghi dehumidifier
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant or Blower speed to low. If the blower doesn’t run when you turn the switch to on then you need to check the blower out, especially the capacitor.
Aug 01, 2009 | Dehumidifiers
Can a fix a cracked blower wheel for my dryer with liquid cement or should I get a new one.
Jul 19, 2009 | Comfort-Aire HD-651 Dehumidifier
Dehumidifiers Logo
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
john h
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
