Question about Brother International BRTTN580 - Brother TN550, TN580 Toner
Fuser needs replacement - Brother International BRTTN580 - Brother TN550, TN580 Toner
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
Xerox 6280 gets error message replace fuser kit, it was replaced and still has the same message
This is an easy one.
The original fuser supplied with the printer DOES NOT have a counter chip. Instead, the PRINTER assumes that when the number of pages printed reaches the level at which the fuser needs to be replaced, the printer issued the REPLACE FUSER message.
If you replace the fuser with another that has come OUT OF a new printer (i.e. a 'PULL' from a new unused printer), since it has no counter chip of it's own, the printer assumes the fuser pagecount is the same as the printer pagecount (because there is no information to read from a fuser chip), and still wants the fuser to be replaced.
A new REPLACEMENT fuser from XEROX, or a CORRECTLY refurbished fuser WILL have a counter chip, and therefore clear the REPLACE FUSER message.
Nov 28, 2012 | Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
My DC440ST have a code U4-2 fuser overtemperature, and display says print engine fault?? please help me
You will need to either rebuild or replace the fuser. Much easier to replace.
Google a business called "the parts drop" . Call and talk to Britt. He will have what you need.
But a U4-2 normally means the thermistors and thermostats need replaced, normally by that time the heat and pressure rolls are worn out.
Which is why I say an entire new fuser would probably be the best route.
Just a couple of thumb screws to replacing it.
Dec 30, 2009 | Xerox DC440ST Copier
I have an error code 50.2 it says i need to remove the fuser ,, where is the fuser located
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204345%20MFP%20sm.pdf
This a link to a 4345 service manual. Fuser is in removal and replacement/user replaceable parts. A 50.2 is the fuser is not warming up to temp. A replacement may ne needed. If the fuser was just replaced you would want to check this pdf
www.lbrty.com/tech/ta4xxx.pdf
Jul 06, 2009 | HP Office Equipment & Supplies
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
Brother International BRTTN580 - Brother TN550, TN580 Toner Logo
11 people viewed this question
Top Brother International Office Equipment & Supplies Experts
k24674
Gil Shultz
Ron Baird
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
