Question about Samsung Televison & Video
No signal from closed circuit system
I bought a Samsung T24C550ND monitor to replace an old analog monitor built in 1997 used in a closed circuit system at our church. The old system uses BCN connections. I tried using a BCN/Cable adapter connecting through the threaded antenna connection, but I get a weak signal/no signal message and nothing but snow. Will I have more success using a BCN/RCA component adapter to feed the signal to the new monitor? Or is there a different method I should be using altogether?
  • Mark Sawyer
    Mark Sawyer Feb 15, 2014
    Connecting the monitor using the composite connection solved the problem. The monitor is working beautifully. Thanks!
  • Samsung Master
  • 3,904 Answers
If you monitor will accept a composite connection (RCA) than I would try that first but the right way to do this is to change the connectors on the cable. Wire length is in play here as well as wire type. Before I ask for more detailed information give the adaptor a try.
Posted on Feb 12, 2014
Highdefjeff
  • 124 Answers
SOURCE: Visco LCD TV VSC-32V3 32
After connecting the cable to the TV, you should scan for channels. With the built-in cable QAM tuner, you should be fine with a scan for channels.
Try another TV to make sure that cable broadcasting is coming in...is there a set-top cable box involved?
Posted on Apr 08, 2008
  • 13433 Answers
Which one is your problem the one on BOLD or the one on normal text?
You have to enable to 2nd screen, is there another computer available to you where you could try this lcd?
Posted on May 20, 2008
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
SOURCE: how to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Posted on Dec 31, 2009
I want to know how to connect an equalier to an 7.1 onkyo surround system
It might not be worth the effort because it would only be useful for analog 2-channel audio. But it IS possible.
Video 1 and Tape have Ins and Outs for the use of any typical analog stereo processor, such as the EQ.
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 07, 2011 | Onkyo HTS3100 Theater System
What is p1451? and how do i fix it
Technical Description:
EVAP Control System Canister Vent Solenoid Circuit Malfunction
The EVAP system monitors the canister vent (CV) solenoid circuit for an electrical failure.
The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified canister vent duty cycle by PCM command.
Symptoms: You will likely not notice any drivability problems.
Causes: A code P1451 may mean that one or more of the following has happened:
*VPWR circuit open
*Damaged canister vent solenoid
*Canister vent solenoid circuit open or shorted to ground, power, etc.
*Damaged Powertrain Control Module (PCM)
*Possible SolutionsVerify canister vent solenoid - To verify normal functioning, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage
(PCM control side).With the valve open, EVAPCV indicates 0% duty cycle and a voltage approximately equal to battery voltage.
When the valve is commanded fully closed, EVAPCV indicates 100% duty cycle, and a minimum voltage drop of 4 volts is normal.
Output test mode may be used to switch output on/off to verify function.
*Replace canister vent solenoid
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2010 | 1997 Ford Taurus
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
When the monitor is turned on it displays "analog, digital" then "check signal cable", what is the problem?
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Sep 11, 2009 | Samsung SyncMaster 932B LCD Monitor
Check signal cable
Turn off the monitor first.
Hold down Function button and click F8 key to tell the laptop to send signal to the monitor.
Apr 20, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Televison & Video Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
