Samsung T24C550ND I bought a Samsung T24C550ND monitor to replace an old analog monitor built in 1997 used in a closed circuit system at our church. The old system uses BCN connections. I tried using a BCN/Cable adapter connecting through the threaded antenna connection, but I get a weak signal/no signal message and nothing but snow. Will I have more success using a BCN/RCA component adapter to feed the signal to the new monitor? Or is there a different method I should be using altogether?
5 Suggested Answers
SOURCE: Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Posted on Apr 25, 2009
  • 84 Answers
SOURCE: Can't get monitor to connect
There are a few things to look at. It is very obvious that the screen is in good condition since you can see the message on it. Now the problem lies with either the RAM and/or the VGA. If you are using an onboard VGA, try a PCI VGA card. Try to resit the RAM modules also. If you have more than one mem chip, then do it one after another. It might be one them is fault and hence blocks the signal to video. Finally, any newly installed card should be temporarily removed ok. With these, I am sure the problem will be over. Good luck
Posted on May 27, 2009
michael_grey
  • 365 Answers
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Posted on Jul 21, 2009
termistor
  • 82 Answers
SOURCE: My Samsung 940t stopped working,
I'm thinking of would be a problem with your PC not booting, try to connect to a computer monitor to know that it works
Posted on Apr 04, 2011
Samsung tv/monitor turns on when it wants to.Once it is on it works perfectly fine. The standby light is on. It is an issue with getting it on initially. It is plugged directly into the wall outlet.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 14, 2016 | Samsung T24C550ND 24" 1080p LED...
Samsung monitor flashes once then nothing - black screen. Why
Circuit board going bad. Sounds like with the issue that you had before and then this one, its time to replace the monitor.
Feb 22, 2015 | Samsung Computers & Internet
No signal from closed circuit system
If you monitor will accept a composite connection (RCA) than I would try that first but the right way to do this is to change the connectors on the cable. Wire length is in play here as well as wire type. Before I ask for more detailed information give the adaptor a try.
Feb 12, 2014 | Samsung Televison & Video
Need Synmaster 216bw driver
Here is the driver download from SAMSUNG website
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=216BW&prd_ia_sub_class_cd=P
Just click on the driver, it is the same one as you listed '20070515103345609_SM223BW'
No need to uninstall the old driver, all the driver doese si to allow you to set the resolution that is not listed in the microsoft video resolution lists.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Samsung SyncMaster 216BW Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Hi, I just bought a samsung blue-ray. I want hook
i can help with that have you looked on the back of the tv at all the jacks you have look at the color of the jacks some are red and white those are for audio and the yellow is video you need a pair of cables that will conect from you dvd to your samsung that same color on both ends their RCA cables or analog cables
Oct 29, 2009 | Onkyo HT-S780 System
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung txe2745 just quit working -- has an internal "clicking" like a relay trying to close
First of all greetings from Belize mike your set is an old set but you can still get some life out of it please be inform that going into a tv could cause you self injury if you are not qualified to handle an electronics set.the problem with your set is in the power supply there is a 10mf cap situated in the power supply just close a transistor replace it along with power requlator and associated diodes.that will solve your problem.but make checks in the power supply.if you cannot do it yourself take the set to tech.good luck.
Nov 21, 2006 | Samsung TXE2745 TV
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
