Electrolux Inspire EWF12449W
Hey. Our washingmachine just stop working last week. We did not get any error in the display. We can not understand what is wrong with it. It drains like normale, but we can not make it work. What can be the problem?
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 6277 Answers
SOURCE: I have an electrolux inspire washing machine, 3
I've attached these filter guidance notes JUST IN CASE this is the problem. It's worth carrying it out regularly anyway ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 23, 2011
  • 6277 Answers
SOURCE: I'm finding my electrolux inspire
John C
Posted on Feb 24, 2011
Chesc
  • 59 Answers
SOURCE: Electrolux Inspire Model EWN14780 W Showing ERROR
E40 code indicates that the door is not closing all the way.
Check the door latch pin.
It's a spring inside the door that forces it over.
If it's being pushed over quite strongly then it's possible that the door may have moved slightly to the left, causing the fault.
Push the latch pin over and trim a small amount of plastic off the door, where the pin rests against.
This will allow it to move over slightly further and activate the lock.
If the spring in the door is broken, you'll need to replace it.
Hope this helps.. Good luck! :)
Posted on Jun 08, 2011
rickead1
  • 1998 Answers
SOURCE: Hi, I have an Electrolux EWF 1074 front loader.
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
Posted on Jul 18, 2011
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
Jan 23, 2016 | Electrolux 36"" Induction Cooktop
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
Dec 04, 2015 | Electrolux Washing Machines
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Why my oven electrolux shows me error code f50 on its display?
Hey Tatiana, thanks for your post!
I understand that your Electrolux range is flashing "F50". I would recommend resetting power to your appliance and you can do that by unplugging or disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue it could be a problem within your EOC (electronic oven control) or UIB (user interface board). Since it could be any one of these underlying issues I would advise to have a professional come out to your home for proper diagnose your appliance. -Matt
Sep 08, 2014 | Electrolux Ovens
Wall oven not heating
Hey friend, thank you for your post!
I understand that your Electrolux wall oven is not heating. I would like to ask some additional questions so that I can better assist you. First, is your appliance displaying an error code of any sort? Secondly, is display on? A step you could try would be to reset your appliance, which is done by either unplugging your appliance or flipping the household circuit breaker for ten minutes. I look forward to your response to better assist you. -Matt
Jul 28, 2014 | Electrolux EW30EW65SS Stainless Steel...
Electrolux Inspire 7 kg washing machine. Error code 22. A program run for 30 minutes Ok and the stop and reset the program. What means e22 and how can be solved? Thanks in andvance!
Hello Serban Alexandru - Typically error code E22 indicates that the water is not pumping out fast enough. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have the pump, timer or main control board diagnose.
Oct 04, 2012 | Electrolux Washing Machines
E70 error code on electrolux dryers inspire, it is working but dries the clothes to damp then this code comes up
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
Sep 17, 2012 | Electrolux Dryers
It comes on for 2 mins and then E50 comes up on display,sorry its an Electrolux Inspire 7Kg Dryer.
is it a sensor dry? is there damp washing in there when you are testing it?, or is it empty as this will tell the PCB to stop as it feels no moisture in the machine
Jan 16, 2011 | Dryers
E 20 error code on electrolux inspire washing machine - what does this mean. Machine now just stopped - wotn commence cycle at all.
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
Dec 21, 2009 | Refrigerators
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
