Question about LaCie 500GB Rikiki USB 3.0 Portable Hard Drive
When installing windows 7 hd not being detected
Trust Webcam 16588 Not Working on Windows 7
click start right click on computer select properties device manager scroll to image devices right click to update driver software
hope it helps
May 08, 2012 | Trust MultiCover WideScreen HD Webcam...
Install graphic card eah5450 on window 7 and the problem come out whereby my computer keep reboot non stop
is it properly installed? try to boot on the safe mode first and let the windows detect and install it first.
Jul 11, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
My window 7 doesn't detect 2nd HD (seagate cheetah st173404). I can see it list in Bio/advance setup/hard disk drives. But I can't see it in boot and also can't browse it in window 7 disk management....
myoung331
If the drive is not being detected properly then ether the SATA port you have the drive connected to does not support the drive or you need to install updated SATA drivers for your motherboard to fully see the drive. I myself ran into this the other day when I upgraded the hard drive in my computer.
If you are not sure if it is supported and/or having trouble finding drivers let me know the make and model of your motherboard.
Issken
http://www.fixya.com/users/issken
Feb 16, 2011 | Seagate Cheetah 10K.7 ST336807LC...
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
HDD cannot be detected after reformatting
Ok, unfortunately, even though, you had two partitions they were both on the same Physical drive, now you cannot "Format & Partition" without breaking the install, as the Win 7 is the "Boss" and when you formatted you have wiped out all you boot track information, You maybe have a shot, if you get a Win 7 install disk, and boot off of it, then ask it to repair your "Boot Sector" this may allow you to Boot into Win 7,if you are lucky. Then you can use as normal. But if you cannot do that, you will have to boot from a Win 7 or Vista or whatever OS you wish to install,and follow the instructions, and do a complete reinstall of the OS. If you wish more than one partition, in the setup, it allows you to choose the size of your drive, so simply do all that, at that time.
May 08, 2010 | Acer Aspire 4720 Notebook
The Speech Component isn't working but the
Ok I have a solution for my laptop. I have Laptop with realtek HD Audio and Windows 7. Rosetta stone did detect the integrated microphone at first, but then nothing helped to do this again. So I decided to upgrade audio drivers. First installer removed old drivers and asked for reboot. I rebooted and DID NOT INSTALLED DRIVERS. Windows installed its native drivers and here we go. I have been learning Japanese for two days already :)
So the solution for windows 7 is:
1. Remove your audio drivers
2. Reboot
3. Wait until windows install its own drivers.
4. Learn languages.
Jan 17, 2010 | Rosetta Stone Computers & Internet
Windows Media Center can't detect a TV signal from a Sabrent card
If you have hd card, it might be your cable company not providing hd signal. If you have analog card, and have HD signal that will cause it too.
Nov 30, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
To play my vietcong game i have to disable sound otherwise it crashs
I had the same problem and solved it by selecting "Disable front panel jack detection" in the Realtek HD Audio Manager "Connector Settings" dialogue box.
Running Windows 7 Ultimate 64-bit on an ASUS P6X58D motherboard w/ integrated Realtek audio chip.
Aug 02, 2009 | Jack Of All Games Vietcong for Windows
I want to install RHEL3.0 in SATA DeskStart HD using MSI SATA MB, but not detecting at OS installation time. HOW i can detect, Pls help me!!!!
You need to create a space for which to install Linux. That likely means resizing Windows. Partition Magic is a good Windows utility to accomplish this, although there is a Linux version called Gaprtedthat will do essentially the same thing. You download the Gparted live cd, burn to disk, and run it from your computer. You must go into "setup" and set your Bios to boot from CDROM before booting the Hard Drive. Once booted, follow the on screen instructions. Resize Windows, (but NOT before a thorough defrag of your Windows drive), and create a "blank space" for Linux. Afterward, boot your Linux distro, (RedHat 9 was a great distro, but a newer version of a Red Hat based distro would serve you better, sayCentOS or Fedora Core), and follow the online instructions. Good Luck!
Sep 25, 2008 | MSI 945GM2 H-F (816909015911) Motherboard
LaCie 500GB Rikiki USB 3.0 Portable Hard Drive Logo
22 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
