MODEL#DRT-S810 DVD RECORDER/VCR COMBO
THE SYSTEM HAS NO POWER TO ANY OF THE INSIDE UNITS
AC POWER COMING IN AND SOME DC POWER WORK.
STILL NO POWER TO TURN ON THE HOLE UNIT. PLEASE HELP.
THANK YOU GAMALIET FIGUEROA, 210-772-4339 SAN ANTONIO TX 78207
  • 10 more comments
  • Anonymous Nov 04, 2007
    I have a trutech DRT-S810 DVD/VCR Recorder Combo unit that has ac power to the plug but will not come on, no lights or nothing. I can't find out who does the warranty work on these units in the USA. Does anyone have any contact info on this. Thanks.
  • WSUGRAD91 Dec 07, 2007
    When I try to power on the unit nothing happens, there is power coming to the device. I am not sure what to do with it, any help would be appreciated.
    The recorder was purchased at a Target store, they have not been much help.
  • GeorgiaEddie
    GeorgiaEddie Dec 09, 2007
    Same problem here! When I plug it in, the DVD light comes on,but no clock blinking 12:00...12:00...12:00. I actually miss that. I sure hate to think I threw away >$200.00. I had used it quite a bit prior to the ????. Thanks!
  • Chris Rankin Jan 01, 2008
    Power to unit but not able to turn it on. There are no pilot lights that come on. Nothing is operational.
  • rondarain Feb 14, 2008
    I lost my manual shortly after getting my recorder. Recently just able to figure it out and burned a dvd successfully last night then powered it off. Deciding to make another copy I was immediately and still unable to power it back on. Please help!
  • alexisb Apr 21, 2008
    machine will not come on it get power and dvd green light comes on..
  • Petey21133 Apr 30, 2008
    Have power going to unit, but unit will not function; green light on unit comes on, but none of the function of the unit will work.
  • jesus12 May 10, 2008
    I have a combo dvd recorder-vhs y I have problems with the items, simply it not work, I would like information about e-mail, adress and phone for send it directly at supplie to repair.
    thank you
    my e-mail is jesusgonzalezm@yahoo.com
  • Petey21133 Sep 04, 2008
    Power going into unit but power inside unit.
  • bootscooter0 Dec 02, 2008
  • Anonymous Jan 25, 2009
    finilize the dvd on trutech drt-s810
  • Anonymous Mar 31, 2009
    How to connect a camcorder to the recorder player on a trutech m odelDRT-S810.
The DVD recorder is like a PC internal drive. Pull the 4 pin molex connector and check the voltages across 1&3, 2&4. Should have a (+ or -) 5volt, and (+ or -) 12volt (you can compare with a PC's voltage across the same kind of connector if you want). If you don't have a 5 & 12 volt reading your power supply is probably bad. Optionally confirm DVD recorder works by removing and attaching to a (spare?) PC.
Posted on Oct 30, 2007
Dont buy. piece of shiyt
Posted on Sep 04, 2008
DON'T BUY CHINA MADE CRAP FROM WALMART OR TARGET
Posted on Jan 27, 2008
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba Televison & Video
TRUTECH/DAEWOO DVD RECORDER/VCR DRT-S810
Hi!
did you check the +5 volts if exactly? and the +9voltsif exactly? now if you got over voltages in the said voltages you got abnormal power oscillation! or did you check the regulator? maybe the ADJUST Pin is in abnormal function! and try to unload the power board then you can test run the power board by checking the voltages in secondary.
Nov 07, 2007 | Televison & Video
Need a download owners manual for TRUTECH CVR/VCR DRT-S810
https://www.2instructions.com/search.php?cmarque=TRUTECH&modele=DRT-S810 Hope that helps.
Jul 26, 2010 | TruTech Televison & Video
Magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Oct 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is there a remote control code for model zv427mg9?
For my direct tv remote, 20675 worked for me :) magnavox zv427mg9 combo vcr, dvd
Sep 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Sep 24, 2008 | Philips MRV700VR DVD Recorder/VCR
Vcr/dvd burner combo
You will have to go into the dvd menu and finalize the disc for it to play on any other player. Check in your manual for more information.
Mar 17, 2008 | Zenith DVR413 DVD Recorder/VCR
Trutech DRT-S810 Does not power on
known issue with this unit. The power supply used in this unit is below quality and is often the cause of power not getting to rest of the unit. The company is from china and does not have a usa warranty service since they operate under the daewoo umbrella.
Dec 29, 2007 | Zenith DVR413 DVD Recorder/VCR
I need a remote
You need to contact "Daewoo/Trutech" directly to get a replacement.  Good luck they are not easy to get a hold of.
Buy a universal remote.  Check the booklet to see if your model is listed before buying it.  This is your easiest way.
Oct 27, 2007 | Televison & Video
Televison & Video Logo
896 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
