Question about Car Audio & Video
I have the JVC kd-x50bt stereo that keeps showing the chk wiring then reset on it and I do so by removing the 10v conduit the sound and the on sequence cable the replace and turn it on sometimes I starts working until I turn up the sound and other times it just doesn't and keeps showing the miswiring icon I had professionally installed and just don't know what to do can you help
  • 3,904 Answers
My first thing I would do is call the installer back and get them to troubleshoot the problem. This should be done free of charge.
Posted on Feb 12, 2014
SOURCE: JVC KD-G720 car stereo - how to change the time?
disconnected the battery an lost all the stations got them back now i can't get the time right  HELP?
Posted on Sep 30, 2008
  • 341 Answers
SOURCE: How to install JVC KD-G396
Here is the manual.
http://www.jvc-australia.com/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Posted on Dec 20, 2008
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
My kd-r446 show on dispay warning chk wiring than reset so how do i reset ?
Hi Divyesh
to reset your stereo, remove the front panel, and look for a small hole to roughly the left hand side of your unit, use a paperclip or something small you can put in the hole, press for about 5 seconds and it will reset the unit to factory settings..hope that helps you..
Dec 17, 2014 | JVC Car Audio & Video
What i do?
Minimize your cabling to just RED YELLOW AND BLACK to see if this is an internal radio issue or installation issue.
Jvc kd-x250 bt installed in my son's boat will not work on the water except in reverse or in the driveway.Never came up on a problem like this before.There was a radio tied in prior,just used the same...
Doesn't work is one way of telling the symptom. In detail, it can also be said " powers on, cannot change channel, etc..). That may help troubleshooting
Oct 07, 2013 | JVC KD X50BT - radio / digital player
How do i reset jvc cd receiver it shows warning chk wiring then reset
May be a wrong model. JVC started this feature in 2009. Your model is older than that.
Aug 25, 2013 | JVC KD-PDR31 CD-Receiver -I-Pod...
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
Nov 27, 2008 | JVC KD-LX100 CD Player
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
