Question about Photography
No picture instax
I have an instal mini 8 camera and it will no longer take pictures. When i turn it on, it doesn't make the noise it normally does and all the lights on the front and the one on the back come on. The problem occurred after I put a new thing of film in it. I took one picture but the blank discardable slide never came out. I tried to take another picture and the camera wouldn't let me. How can I fix my camera?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Try a different pack of film. Sounds like the one you have is jammed -- possibly caused by moisture condensation.
Posted on Oct 06, 2017
cammedic
  • 667 Answers
SOURCE: My minolta sightseen camera wont take pictures?
The blinking zero would indicate that the film has not loaded but the cartridge is in place. The camera won't do anything when this occurs. Try opening the film door and load the roll again
Posted on Jan 14, 2008
  • 906 Answers
SOURCE: fujifilm instax 200 camera will not spit out pictures! :(
Link
Camera might be damaged because of the fall, suggest to consult the Authorized Dealer near you (-see above link), or send it back to the store where you purchase it as it may be still part of the warranty.
Thank you
Posted on Jul 29, 2010
Obertelli
  • 3006 Answers
SOURCE: I just bought new Lomo
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Posted on Aug 12, 2010
tbreeze47
  • 3083 Answers
SOURCE: The neck ******** my fujifilm
The film had a leader, which is meant to be sticking through the top of the camera. The only thing I can figure you can do is to take the film out of the camera, in dim lighting or a dark room, if you have one, and reinsert and guide the film pack in correctly.
There's no guarantees that the film will be good anytime a camera has been opened, but it might, so it's worth a try. What have you got to lose...
Good luck, hope this works for you, and thanks for using FixYa.
Posted on Sep 13, 2010
  • 304 Answers
SOURCE: what does the E mean
If you go to http://www.pentaximaging.com/support/manuals-and-literature/ you can find the manual for your camera. From my experience the E on a Pentax camera means the film isn't loaded properly. Hope this helps.
Posted on May 11, 2011
My Fujifilm Instax Mini 8 is stuck on S and wont take pictures. What does that mean and what do I do?
Look it up in the manual. As you have described the item as disposable, why not do just that and buy one which works ?
Apr 28, 2016 | Fujifilm Instax Mini 8 Camera - Pink
My fujifilm instax 8 won't take a picture (blue)
I had the same problem as you. When the film goes blank you noticed that the back is brown, not black? Well that is because you are not bursting the bubble of ink that comes in the bottom of the film.
What I had to do was open my camera and fix a small detail. It turns out that the control lever light intensity has a spring that can be moved from its original location. We must accommodate that spring to get everything back to normal. I have some videos of how I did. I hope to edit them soon so you can see how you did.
May 19, 2014 | FUJIFILM instax mini 7 Digital Camera
Fujifilm instax mini 7s pictures coming out white
I have the same problem as you. Pictures are in black and photo cartridges already wasted 3. Today I opened my camera and not a spring tea that is attached to the lever capture modes (sunny, noblado etc) was detached. Because I remember when the camera is turned on (pulling the lens) capture modes to move too. So every time you take a photo you must manually set the capture mode, and it stopped working. I hope it is resolved by attaching the spring. You already solved?
Jan 21, 2014 | FUJIFILM instax mini 7 Digital Camera
My instax mini 8 won't turn on.
hi there.
not sure if this link will help you out but have a look.
My instax mini 8 won turn on Google Search
Nov 17, 2017 | Cameras
Instax mini 8
horizontal varde owar size sony tv model no kv-hv21f83a
Dec 25, 2013 | FUJIFILM instax mini 7 Digital Camera
The red lights are flashing every time i try to take a picture.. but i changed the batterys and every thing whats wrong?
doesn't the films come out of it?
this repair is tough, recommend you to send it to shop that do camera repair
Jun 29, 2012 | Fuji instax mini 7S Film Camera
Hi. i just bought my instax mini 7s and it wont turn on. The first time i tried it was okay. Then the second time i tried it wont turn on. There's nothing to do with the batteries obviously becaus
I have the exact same problem
and i still have no idea what to do with it
i tried changing the batteries and everything
but it just wont turn on
there are no lights where you change change you settings
and i can't take any pictures with it
someone please help
Apr 26, 2012 | FUJIFILM instax mini 7 Digital Camera
How to known if there is nothing wrong just by looking at the fuji instax mini25
You do it the same way you make sure there's nothing wrong with a used car just by looking at it.
The only way to show that a camera works correctly is to take some pictures with it. Even then that doesn't show that there's nothing wrong with it, just that some things do work correctly.
Apr 24, 2012 | FUJIFILM instax mini 7 Digital Camera
My fuji instax mini 7s has an error message on the screen. It blinks "E" and does not allow me to take any pictures. The instructions and manuals that came with package are all in japanese and i...
Firstly, remove the remaining films in your camera (while the camera is switched off) Secondly, switch on the camera. Press the power button and the shutter button simultaneously at one go. (to reset) Thirdly, reload a new set of polaroid films. Hope it helps!
Nov 05, 2010 | Fuji instax mini 7S Film Camera
Photography Logo
775 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
