Question about LG 42LG50 42 in. LCD HDTV
I have sound but no picture can you assist
When it was turned off this morning it worked. When turned on this evening the blue screen shows then goes blank as if not on but I have sound
  • 47 Answers
Power supply trouble check caps and inverter board.
Posted on May 26, 2014
5 Suggested Answers
  • 134 Answers
SOURCE: nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Posted on Oct 07, 2008
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
Clagnut
SOURCE: When i turn on the
I have exactly the same problem with the same model tv. I am currently scouring the internet to try and find a solution to fix this problem. If you find one before I do, please share your findings and I will do the same. It has been suggested that it could be capacitor failures in the power supply unit. I have not looked at the psu yet to see if any capacitors are "bulging" I want to be sure before I start changing components.
Posted on Dec 13, 2010
  • 122 Answers
SOURCE: When I turn on the tv the screen stays blank and
Hmmmm.... most likely cause is a power supply failure.
They do occur suddenly, since electronic components are at most stress upon switch-on.
Posted on Jun 08, 2011
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
I can turn power on and i will get sound but no picture. I can get different channels up & down with sound only ,but no picture. It seems that the picture has totally failed as there is no on screen...
This can be caused by a main board failure or a t-con board failure. There is a fuse on the t-con that fails but it is not the standard looking fuse. It is an extremely small, surface mounted component fuse. You have to know what you're looking for to find it. It can be bypassed momentarily and if the picture comes back then the t-con is the problem for sure. You really ought to take it to a shop as this is not something that is easily diagnosed at home.
Aug 28, 2010 | Olevia LT42HVi 42 in. LCD Television
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
LG 42LG50 42 in. LCD HDTV Logo
48 people viewed this question
Computer Repairing
Computer Repairing
