Need to pair uniden bluetooth with ps3 - Computers & Internet
  • 3,320 Answers
Posted on Mar 14, 2014
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
How to pair my bb curve to uniden BT112 bkuetooth
You need to put the bluetooth into pairing mode.
Jun 26, 2012 | Blackberry Curve 8350i
How do i connect this headset
Pairing the Headset
Pairing is a process of associating Bluetooth devices with each other.
It will establish a permanent security link between the devices and
enable quick access to the services provided without the need to reenter
Pass Keys. You will only need to pair your PS3 and the Headset
once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Mar 13, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do u pair the 903 back beat with the ps3
You need to make sure the device your trying to pair is Bluetooth 1 1.1 or 2.0. If it is, it should work. However, if you already paired the device with, say a phone, you must clear/remove registration from the phone before using it with your ps3. Same thing happened to another user. They had to unregister it with their phone first before they could pair it with their ps3. Then follow the pairing instructions for the headset and ps3. I hope this helps.
Good luck from Headsets Direct!
Feb 18, 2011 | Plantronics Backbeat 903 Bluetooth...
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My Bluetooth V2.0 with not pair or scan intp my ps3
PS3 supports Bluetooth V2.0, in fact the Playstation branded headset is V2.1. All versions of Bluetooth are backwards compatible. Are you sure that the headset is going into proper pairing mode?
See these tips:
Pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Pairing to PS3:
http://www.fixya.com/support/r5009279-pairing_headset_playstation_3_ps3
May 06, 2010 | Motorola Mobility Bluetooth Hands Free...
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
I want to connect it to my ps3 but its not reading it
Pairing bluetooth devices isn't tricky its just a bit finicky. 1. Go to Settings tab in the PS3 menu. 2.Scroll down and select "Accessory Settings" 4.Scroll down and select "manage bluetooth devices" 5. Select "Register New device" The PS3 will now go into a pairing mode and search for any bluetooth devices. 6. At this point follow the manufacturers pairing instructions for you bluetooth device.
I managed to pair my X3 Micro headset to the PS3.  I had to get on line to find the devices code because I had forgotten it, but after entering the right code the PS3 hooked it up and I have been insulting those who kill me online ever since :P
May 05, 2009 | Video Game Consoles & Games
Computers & Internet Logo
David Payne
David Payne
