Question about Sewing Machines
How do I correct stitching on a Jones z-690
My Jones z-690 (foreign) sewing machine is not stitching correctly. Every 20 or so straight stitches it then does about 6 zig zag stitches! I have the instruction book but there is no solution to this problem in it. Can you help?
4 Suggested Answers
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
aeroseek
  • 55 Answers
SOURCE: My machine sews straight when set to zig zag and
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
Posted on Dec 12, 2010
wendytoon
SOURCE: how do you set the zig zag stitch on a Jones
I have been gifted a Jones ym260g. Does it do straight stitch and if so, how?
Posted on Jan 16, 2014
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Brother 888
To sew a straight stitch, you should have the stitch selector on the straight stitch, the width should be at zero, and length should be in at the halfway point on your selector.
Apr 26, 2014 | Sewing Machines
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
How do you set the zig zag stitch on a Jones sewing machine. Iam setting the stitch size on the zig zag button but can only get it to sew in a straight line
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
Aug 25, 2009 | Sewing Machines
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
