Question about Craftsman Garage Door Opener 1/2 HP Chain Drive
Garage door meote not programing , but key pad will program ?
Remotes wont program to open garage door, I follow manual directions to program the remote, I check to make sure its not in lock position,its not flashing on the wall unit, the key pad out side programs fine to open + close door but not the hand held remote, and I even bought a new remote to see if that was the problem ? help ?
4 Suggested Answers
  • 217 Answers
SOURCE: craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Posted on Mar 10, 2013
swolfinor
  • 504 Answers
SOURCE: Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Posted on Dec 15, 2014
  • 130 Answers
SOURCE: I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
Old remotes won't work. You'll have to buy a remote for your model or purchase a new universal remote such as clicker..
Posted on Jan 01, 2015
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 hp security door opener
OWNERS MANUAL FOR ALL CHAMBERLAIN MODELS ARE AVAILABLE (FREE PDF) AT CHAMERLAIN.COM
CHECK TO SEE IF THE LED IN THE WALL BUTTON IS BLINKING - IF IT IS PRESS THE LOCK BUTTON AND IT WILL STOP THEN TRY TO PROGRAM YOUR REMOTES.
IF IT IS NOT BLINKING TRY UNPLUGGING THE UNIT FOR ABOUT 5 MINUTES - PLUG IT BACK IN AND TRY TO PROGRAM THE REMOTES
HOPE THIS HELPS
May 19, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Trouble with programing garage remotes and keyless entry pad
Either the keypad is the wrong model for your opener or it has reverted to an earlier technology and needs to be replaced. It is important that you get the model number off your motor unit so you can be sure you get the right keypad for your opener.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
I have a 51-C Camberline Gar. Door Remote Where can I find match
The klik-1 will code in to this opener. The directions on the manual are very specific, but if followed it will work. There is also a number for step by step help on the directions. Thanks BB
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener 1/2 HP Chain Drive Logo
27 people viewed this question
Top Craftsman Building Materials Experts
hpgwva
L Pfaff
L Pfaff
richie46
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
