Question about Kenmore Dryers
Noisy clothes dryer 110.67032600
Noise
Dryer shutd off.
see the next steps and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out.replace the belt along with the idler pulley.
Idler pulley
Dryers have a tension or ideler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing houses if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower whells pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower whell Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor
Jul 09, 2013 | Dryers
My Inglis dryer is 9 years old, just started a ticking noise as it spins, what are the most common solutions for ticking noise?
Hello there and thank you for choosing fixya
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Aug 03, 2011 | Dryers
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
Dryer makes a squeaking noise when running
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Loud Noise From Dryer
*Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
*Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
*Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
*Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
*Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Sep 03, 2009 | Maytag Dryers
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Aug 18, 2009 | Maytag Dryers
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
