Question about HMF Polaris Ranger 500/800 Efi 2010 Swamp Series Slip On Exhaust System
I have a 2010 Ranger 500. It runs a while. then misses and goes dead. After waiting a while it will go again, but then does the same thing again. I have check fuel and changed fuel pump and this has not helped.
Hard to shift out of 1st gear
hard to shift gears - Polaris ATV Forum
www.polarisatvforums.com > ... > Polaris Sportsman
Jun 28, 2010 - my 06 500 efi creeps and sometime is a little hard to shift. the dealer told me ... inline. if its off a little when you are stopped and trying to shift the tranny has... 2013 RZR XP 900 .... shop, for first service and to put in a new belt, blew up the firstone already. ... what makes a polaris crew hard to change gears.
Won't shift with motor running. Need help please - Polaris RZR ...
www.rzrforums.net > ... > General RZR > RZR-S Specific Discussion
Mar 6, 2012 - It will not shift in any gear with the motor running, but if I turn it off I can.... First Name: Jeanie ... 2013 Grizzly ... LE - Muzzy, UMP, Donaldson, TS Seats, FixMyToys parts.. and a lot of hard work .... 2005 polaris sportsman 500 shifter problems stuck in reverse ... polaris ranger 700 crew wont shift when running. How to adjust shifter
Nov 27, 2013
Issue: In gear, but will not drive
Oct 22, 2012
Gear Grinding
Oct 7, 2012
HELP trans is hard to shift
Jan 26, 2011
More results from www.rzrforums.net
Ranger Problems & Solutions [Archive] - PRC Polaris
Dec 30, 2015 | Polaris 2013 Ranger Crew 500
Overheating and stalling
Search Results
    2011 XP 800 overheating - Polaris Ranger Club
    www.prcforum.com/.../26-ranger.../29358-2011-xp-800-overheating.ht...
    Sep 9, 2010 - 10 posts - ‎5 authors Member #: 12988; Join Date: Sep 2010; Location: Glasgow, Missouri; Posts: 11 ... He said it started "stalling" and running rough then he noticed the heat ... My week old 2011 Ranger 800 XP/LE doesn't run hot but the fan does ... Thread: 2011 ranger 800 xp **hot** **won't run
    Apr 4, 2012
    2011 800XP overheating and getting worse.
    Sep 20, 2011
    Thread: 2010 ranger 800 xp overheating
    Aug 21, 2011
    Thread: 2010 Ranger 800 stalling from low idle when ...
    Sep 1, 2010
    More results from www.prcforum.com
Nov 05, 2015 | Polaris 2010 Ranger 800 XP
2010 polaris spotsman 500 motor runs rough and backfires.?
firing order is wrong/timing has changed. have you been fiddling with it. otherwise it could be a faulty spark plug.
Sep 02, 2014 | HMF Polaris Ranger 500/800 Efi 2010 Swamp...
Truck won't start with warm emgine
Check the starter, i have seen this before with several vehicles. Maybe install a heatshield between the headers and starter. Get the starter tested also.
Apr 18, 2014 | 1987 Ford Ranger
My 2010 ranger idles fine when cold, but cuts out when idling warm
Have a local shop or auto parts store read the fault codes, it sounds as if you may have an o2 sensor that is out of range.
Dec 26, 2011 | 2010 Ford Ranger
What's your problem?00 nissan frontier barely idles
i had the same problems about a year ago i took it to my buddies shop hook up the computer and it coded the distributor had gone bad it usually runs about a 400-500 dollars to get it replaced.
Nov 22, 2011 | 2000 Nissan Frontier
My i phone screen has gone dead. I tried oressing button on top and by doing that apple sign comes on screen but goes off after some time and again screen goes dead.
Youre iPhones problem is for some reason, its default settings are (too heavy) so put it into DFU mode and restore it. DFU mode = Hold the home button and the top button for 10 seconds then release the top button and wait...make sure its plugged into the computer or it wont work. wait until the computer and iTunes detects that its in DFU mode. Then restore it.
Oct 29, 2009 | Apple iPhone 3G
My 95 ranger cold starts perfectly after it runs a short while it wants to go dead sounds like it is backfiring
my 95 ranger will start and run fine most of the time but sometimes when it starts it goes dead starts again and goes dead thought it was a fuel problem but all of this is good acts like a sensor or computer problem
Sep 18, 2009 | 1995 Ford Ranger Supercab
The engine runs and then stops after running. I wait and then it starts and runs again for about 1 minute and then stops again.
I have a old 2010 Diesel did the same. It was the fuel return line from the pump to the fuel tank. It's a short ? 10" long line.
Replaced it, now it runs for ever.
Barry
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
HMF Polaris Ranger 500/800 Efi 2010 Swamp Series Slip On Exhaust System Logo
57 people viewed this question
Top HMF Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a HMF Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
