Question about Bosch Drills
Drill stopped working
The drill was working fine then it got hot cooled it down started to use it again then stopped again now it doesn't work
  • 45 Answers
SOURCE: My Briggs & Stratton 5 HP engine stops running when it gets hot.
ok,let's assume that you have a good set of points and condenser.and that the air gap is set correctly.i believe it's .20 thousands. when they are subjected to heat.magnets can lose their magnetic field strength.so i would look at my coil and then flywheel. hope this helps
Posted on Apr 30, 2009
motor1258
  • 6674 Answers
SOURCE: 1997 Honda Accord. The compressor clutch and the
Could be a little low on freon as well, causing it to cycle on, off too quick.
Posted on Jul 11, 2009
roniecon
  • 6927 Answers
SOURCE: AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Posted on Aug 29, 2009
  • 61 Answers
SOURCE: Drill stopped work ing when hot. One drill we
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Posted on Oct 28, 2009
  • 211 Answers
SOURCE: my hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Posted on Dec 16, 2009
2004 Saturn Ion AC stops cooling while the car is sitting still. Just started. works fine going down the road.
Does the cooling fan come on when you turn on the A/C ! How hot is it where your at an what is the relative humidity ? How do you know refrigerant level is good ?
Aug 03, 2015 | Saturn Cars & Trucks
I have a 94 mustang with an electric fan. The fan works perfectly when i start the car and its cold. when the temp of the water gets up to about 185 the fan kicks on . it can idle all day and the fan works...
is the car running hot? some cooling fans never come on going down the road because the air comjng through the front of the vehicle keeps the car cool enough that it doesn't need to come on. but if it is overheating then you may want to check the cooling fan relay.
Jul 19, 2011 | Ford Mustang Cars & Trucks
Was drilling a 1" hole the drill got hot and
Motor coil windings burned out - take to repair shop or buy a new one
Feb 15, 2011 | Dewalt 18 Volt Compact Drill Kit
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Oct 28, 2009 | Milwaukee Tool Drills
My 2001 case 586e forklift will just quit running
check the fuseable links arround the starter
somtimes they seperate when they over heat and the ruber contracts when they cool down
if they are cooked they will pull apart fairly easily when hot
Sep 16, 2009 | Milwaukee Tool Case Heat Gun
Drills Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
