Question about LG Studioworks 563N 15" CRT Monitor
Monitor Reset Problem
Any Adjustment of brightness,contrast,vertical & horizontal monitor is auto reset and not completed the manual setup.
  • LG Master
  • 783 Answers
Id try a different monitor to start with.
What program are you using when it blanks out?
Posted on Feb 24, 2014
4 Suggested Answers
  • 624 Answers
SOURCE: Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Posted on Jan 31, 2007
pravinbhavsa
  • 348 Answers
SOURCE: How to to reset monitor setings ?
press menu highlight reset press select .then select ok and press select your monitor settings will reset
Posted on Apr 14, 2010
indus3
  • 212 Answers
SOURCE: the auto image adjustment text displays on screen automatically
you can enter the OSD of the display and turn off the automatic display config. you can find a description to do this in the display's user manual.
Posted on Apr 21, 2010
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Picture not adjusting to full screen an dmonitor buttons Exit, brightness, contrast and Menu are not working also. Checked all buttons contacts are ok.I tried to search for vertical and horizontal variable...
You will need to reset the resolution to fill the screen. That is done through Windows.
If the actual menu buttons on the screen are not working, you probably need a new monitor.
var fctb_tool=null; function FCTB_Init_5ddec69ff7a64d918e9c62baf4d86075(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4b77af1c80d64567931291644b9994c7(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell E773C 17" CRT Monitor
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
May 11, 2010 | HP w2207 Monitor
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
Iiyama Pro Lite E485S
do exactly this:
- power off monitor with the POWER button!
- unplug power cord
- hold -/+ and keep holding them when briefly pressing POWER to get the monitor back on
- press menu
You are now in the service menu. Adjust the settings as you like.
- press EXIT
- power off monitor with button
- power on monitor with button
- AUTO SETUP... will be performed
- re-adjust brightness/contrast
Done!
edwin (rdam nl)
Apr 16, 2008 | iiyama Pro Lite 38a Monitor
Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Dec 06, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
"Auto" always worked but now messed up; can't fix
I had same problem and eventually it died after degrading further a few months later. Other monitor works great...
Oct 27, 2007 | Videoseven V7 R19WPS 19" LCD Monitor
LG Studioworks 563N 15" CRT Monitor Logo
70 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
