Question about 2000 Ford Ranger - XLT - Fender Flares - Original Equipment
#6 CYLINDER MISSFIRE - 2000 Ford Ranger - XLT - Fender Flares - Original Equipment
    Top Expert:
  • 2,044 Answers
Because it says number 6, does not mean it is. The Knock Senors senses PHASES.
Bad Plug
Lifter Failure
Spark Plug Failure
Wire
Injector
Posted on Feb 13, 2014
Missfire on cylinder 8 on bmw 545
move the ignition coil to another cylinder and see if the miss fire moves. If so replace that ignition coil. If the miss fire stays on that cylinder it is more likely the fuel injector. Was their carbon on the spark plugs when you removed them? This is indicative that the fuel injector is gummed up.
Jan 18, 2013 | Cars & Trucks
Missfire cylinder 8 545
Move the ignition coil to another cylinder and see if the problem moves. If it does it is the ignition coil replace it otherwise it is probably the fuel injector.
Jan 18, 2013 | BMW Cars & Trucks
I have a 2002 Nissan Altima 3.5 SE About a week ago the check engine light came on, it started running rough, especially at idle. Computer diagnostic results showed missfire in cylinder 6. I replaced...
i would definately replace the coil. pretty certain that will solve your problem. do not drive with misfire or that can cause fruther damage such as catalyst failing, which is prety expensive.
Aug 17, 2011 | Nissan Altima Cars & Trucks
Check engine light flashing runs rough not firing on all cylinder2000 lincoln navigator with large triton engine Hooked up diagnnostic and it said 1. system too lean bank #2 2. Unable to bleed up fuel tank...
you may try your rotor button and distributor cap. and spark plug wires. try your map sensor also they tend to cause a lot of misfiring if they go bad.hope this helps.
Apr 20, 2010 | Lincoln Navigator Cars & Trucks
take of the fuel filter and blow it out. i had the same problem with a 2008 ford f150 5.4 v8.
Apr 19, 2010 | 2003 Lincoln Navigator
I have 1999 318 4x4 dakota with fault coads
These are misfire codes.This means that your vehicle is missing.The 300 is a random misfire and the 305 is for cylinder 5,and the 306 is for cylinder number 6.Check the plugs if they are good then you could have bad coils.They are top of the plugs.Hope this helps.Good luck.
Feb 25, 2010 | 1999 Dodge Dakota
I have a 2000 gmc sierra 5.3 with a number 6 cylinder missfire. things i have done so far: 1. compression test on number 6 tested fine,as well as the rest of the cylinders 2. leak down test. Held...
I would check the valves for number 6. If one or both are burned, stuck or out of adjustment it would cause your problem. If a cam lobe for that cylinder is burned or badly worn it could be the culprit.
Jan 10, 2010 | 2000 GMC New Sierra 1500
1998 honda civic cel code 71-74
code 71 means #1 cylinder missfire 72 Means #2 cylinder missfire 73 means #3 cylinder missfire and 74 means #4 cylinder Missfire
May 29, 2009 | 1998 Honda Civic
2000 Ford Ranger - XLT - Fender Flares - Original Equipment Logo
96 people viewed this question
Top Bushwacker Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
Jonathan Buck
Jonathan Buck
David Ellis Rhea
Are you a Bushwacker Vehicle Part and Accessory Expert? Answer questions, earn points and help others
