Question about Sharp Mx-2600n MFP Copier
Sharp mx2600n copier error message server not found'
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
  • 32 Answers
SOURCE: Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Posted on Nov 05, 2009
  • 255 Answers
SOURCE: Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Posted on Nov 11, 2009
  • 33 Answers
SOURCE: e7-06 sharp mx2600n
Decode error trouble: Compression
decode error (A compression file cannot
decompressed.)
1) Check the installing state of the PWB. (PCI bus)
2) When an error occurs during a FAX job, check
the installation of the FAX PWB. In the other
cases, check the installation of the MFPcnt PWB
and HDD.
3) Replace the MFPcnt PWB.
Posted on Jul 20, 2010
  • 46 Answers
SOURCE: Our Sharp copier MX3501 is
The scan location (i.e. email, ftp, network folder, computer with sharpdesk) can't be found check the address details and make sure they are correct.
If it is a sharpdesk scan then the most likely reason is that the IP address of the computer has changed (DHCP).
If FTP or Email check the address of the server you are sending to.
Your IT or Service provide should be able to help give you the correct addresses and authentication settings for these.
Posted on Oct 21, 2010
What does error 85-01 mean on a sharp printer?
Hi do U mean H5-01 if so clear paper jam put it in Copy mode press on the keyboard. P * C * 14. CLICK EXECUTE and press Yes then press the COPY TAB IT should reset. Good luck
Nov 01, 2016 | Sharp Office Equipment & Supplies
What number will I use to reset the PTC unit in sharp copier mx2600n
I assume you have a C4-** code displayed.
The PTC unit is failing, if you turn the copier off & on then this will reset the machine. If the error is still there then the PTC will probably have failed & will need replacing.
Hope this helps.
Dave.
May 03, 2016 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
How do I run a service mode to reset the machine MX2600n
press program,*,clear,enter 14 press start then turn machine off and then back on.
Nov 23, 2013 | Sharp Mx2600n Color Copier, Printer,...
Selected servers not found
This is a common error when using Sharpdesk and the Network Scanner tool. Take a look at my cheat sheet on how to fix this problem.
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Aug 26, 2013 | Sharp MX-5001N Copier - 50 PPM Full-Color...
Unlock password Problems for sharp mx-2300g
Here's a link to a site that has the user manual. It's free to download, but you'll need Adobe or Nitro PDF reader to open it. I found the instructions for the same thing for my copier in its' manual. Good luck!
Aug 31, 2012 | Copystar Sharp MX-2600N Copier : Sharp...
What does maintenance code DC mean on a Sharp MX2600N
http://www.printcopy.info/?l=en&mod=docs&brand=Sharp&prefix=MX&gID=19349
Above is the service manual, and below is your user manual, the information you require will be in them.
sharp-world.com/products/copier/.../MX3100_2600N_CTLG_S.pdf
Jun 22, 2010 | Office Equipment & Supplies
E7-06 sharp mx2600n
decompressed.)
and HDD.
Feb 12, 2010 | Sharp Office Equipment & Supplies
When scanning, received error message "selected servers are not found. Consult you network administrator." Never received this error before, and as the administrator, I have not changed any settings.
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
Oct 27, 2009 | Sharp MX-2700N Color Copier
Sharp Mx-2600n MFP Copier Logo
120 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
