Question about Black & Decker Bread Machine
How to replace the shaft of a bread machine
Shaft not turning
I need a drive shaft for the bread pan
Bread machine parts finder on EBay has parts for many types of bread Machines. They also have guides on how to replace.
Oct 05, 2011 | Breadman TR2500BC Bread Maker
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
I have a Regal bread maker K6773. At the bottom of the drive shaft in the bread pan is a tan rubber gasket and below that was a black rubber gasket that has completely disintegrated and ended up mixed up...
Hi..That assembly is part of the sealed bearing in the bottom of the pan. That sealed bearing allows the shaft and paddle to turn freely. Unfortunately Regal stopped making bread machines and parts several years ago so the chances of you finding a replacement is rare. Hank
Sep 21, 2010 | Regal Ware Kitchen Appliances - Others
Rotating shaft will not rotate - during the kneading process nothing happens
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Aug 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
I have a brand new West Bend "just for dinner" bread maker. In the bottom, the two-pronged part which the motor is supposed to turn, doesn't turn. Thus, the kneading spatula doesn't turn. The heating unit...
If the machine is brand new, then take it back for an exchange. If that's not possible, then call West Bend for a replacement. If that's not possible then let's try to solve this problem in a few steps. 1) Take pan out of machine and see if you can spin the paddle on the shaft. If yes...next step..if no then bearing in bread pan is stuck. 2) Put bread pan in machine and lock in place. Start a kneading cycle. Look through plastic lid to see if paddle turns. If no step 3. 3) Take pan out of machine and start kneading cycle. If motor shaft does not turn, then the belt fell off the pulley in the machine or belt is broken, or the motor is bad
Hank
Nov 15, 2009 | West Bend 41077 Just For Dinner¿...
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Hitachi bread maker
I had the same problem after storing my machine for several years, BUT, I lucked out...I just added a little warm water to my pan and then turned the machine on and let the paddle turn a few rotations and walla!!....it freed itself and is now making great loaves once again!
Jan 26, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Replacing belt on bread machine
Where did you get the replacement belt ? My brother is looking for a belt for a similar model K6761 which uses the same belt (I think). It is about 24" around and 1/4" wide. It has (3) grooves inside and the backside has many notches. The motor has grooves, it would go on there. Where did you get the replacement belt ? thanks regus_patoff_2000@yahoo.com
Feb 02, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Black & Decker Bread Machine Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
