Question about Konica Minolta bizhub C250 All-In-One Laser Printer
My Konica Minolta Bizhub c352 sporatically having a Malfunction C-FD07. Recently, I replaced both boards, and the hard drive.
  • Konica Minolta Master
  • 6,696 Answers
You replaced the MFB board? next is check each connector one at a time remove each connector from the boards and check the connector on the board there might be a bent pin,
Secondly, have a tech come out and re-flash the firmware on the machine, firmware is not available on line as it is the property of Konica Minolta so only dealers and KMBS have access via secure web server
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 25, 2016
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
SOURCE: SMB Scanning to a Macintosh
SMB can be a bit tricky on Mac as the aliases etc, & paths can easily overwhelm the MFP. Try FTP as a better alternative. Use "Locations" on Mac to setup a static ip# they can switch to when scanning. I have found the KM machines a bit more fussy than Canon with regards to SMB as you can usually browse better on the Canon devices. I have seen the "Reference" browsing on KM allow you to see into the Mac yet will not allow scanning to the set location. Our KM reps always recommend using the ip# of the device vs Netbios name. To me that sort of defeats the point of using SMB anyway. Scan to PC over SMB seems ok to computer Netbios name as long as DNS is registered & working OK on the LAN & WINS is properly configured as well.
Posted on Jan 21, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do I fix error message C3452?
It is most likely your fusing unit. Part number 9J06 R706 00 .
If you have had any power surges recently, meaning lightning struck your building and something else was hit. It could be the main board. You need to put a surge protector on this machine either way.
Oct 03, 2014 | Konica Minolta Office Equipment & Supplies
Bizbub c352 malfunction detected c0206
open all the draws and check to ensure no paper behind them install the paper properly in the draw DO NOT STORE PAPER ON THE LEFT SIDE OF THE DRAWS ITS NOT A STORAGE AREA IT IS FOR 11 x 17 PAPER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Worse case you blew out the draw motor and main board?
Apr 10, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Malfunction C-FD07 happens every few mins on my Konica Minolta Bizhub c352. Any ideas? I've reset the machine a millions times
I would recommend that you have the software on the printer control board be re flashed with the latest software. Have a technician come out and do it. The software is from a secured web site for Konicaminolta. . Not a driver software. In the process might help with other issues when this is done. The code has to do with the copier's Image Printer Control board. Very Expensive hope that is not your problem. I would bet on the firmware first.
Feb 27, 2014 | Konica Minolta bizhub Office Equipment &...
recommend that you have a tech come out re flash image control board firmware, no not avail on internet, copier company protect there software, worse case the image control board is bad, YOU REPLACE THEM FIRST GO THOUGH EACH CONNECTOR and pulling them out one at a time and check for a bent pin, then re seat each connector.
Feb 12, 2014 | Konica Minolta bizhub C250 All-In-One...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
