Question about Lexmark Wheelwriter 15 Series II Typewriter
I have an eIBM 6783-2 electronic printer but the hammer is not sticking with pattern
  • Lexmark Master
  • 3,594 Answers
If you are trying to say not striking the platen you have a a bad print solenoid cap.
We se4ll them for 20.00 with instructions.
DickyO
216-269-3918
Posted on Feb 13, 2014
The hammer does not strike on the platen
You need a print solenoid cap. We sell them with instructions for 20.00.
DickyO
typewroterguy@att.net
Mar 09, 2015 | IBM Wheelwriter 10 Series II Typewriter...
My IBM 6783-2 will not print any letters and the hammer is not striking the wheel
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Feb 12, 2014 | IBM Wheelwriter 6 Typewriter
You have a bad print solenoid cap.
We sell them for 20.00 with instructions
.DickyO
216-269-3918
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
Dewalt demo hammer, when switched on the motor speed surges up and down constantly. What is wrong?
Check the brushes first. If they are worn or sticking they could cause this.
If the brushes are fine and not worn down then it is most likely the electronics/ variable speed module.
May 09, 2012 | Dewalt 15 Amp 3/4" Hex Demolition Hammer -...
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Oct 06, 2009 | IBM 6400 Matrix Printer
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Apr 08, 2009 | IBM Office Equipment & Supplies
Regal breadmaker manuel for 6783
go to http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Oct 14, 2008 | Kitchen Appliances - Others
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
Lexmark Wheelwriter 15 Series II Typewriter Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
