Question about HP LaserJet Office Equipment & Supplies
HP 2300d 49.ooff service error
I keep getting this error message when I turn on the printer. It comes up with the "Ready" screen and then quickly goes to "processing Job" (there is no job to process & I have tried "cancelling job" at this point) and then comes up with the error message
MUKHTAR
  • 2017 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
SOURCE: HP 8550 not printing
Disconnect your network cable and printer's hard drive and then power on. Its possible there is a stuck job somewhere.
If that doesn't work, believe or not it could be the fuser.
Posted on Jun 06, 2009
  • 3278 Answers
SOURCE: Printer stalls when sent a print job.
I'd suggest reinstalling the printer driver.
In Start - Printers and Faxes, find the printer and delete the icon. Power off the printer and disconnect the cable from the printer to the PC. Restart your workstation and log in. Reconnect your printer cable to the PC. The printer should be found. Install the driver and the printer should work. Good luck.
Posted on Jun 12, 2009
Error 49.38.07
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
Jul 08, 2014 | HP Laserjet P3015X Printer
Hp color lj cp4025 error 49.2fa7 code how to clear
see
HP color LaserJet cp4525dn error 49 2fa7
suggestion.
Disconnect the network cable or usb cable and try again. If the message does not come on, you have a bad job trying to print each time the printers signals the network it is ready. You need to delete the bad job. Sometimes you can keep the network cable disconnected until it comes to ready and then plug it in and keep hitting the cancel button in attempt to cancel the job, but most times you need to delete the job at the computer or server which is sending it.
Jun 23, 2014 | Office Equipment & Supplies
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
I have a error 49 when the machine comes up and blank screen with just the fan running ervery other boot up . i thinkit maybe the formater board
A 49 Error usually always points back to the formatter, however I would at least attempt a cold reset here are the directions:
1. Turn off the machine
2. Simultaneously press and hold the Cancel button and the right arrow button (> ), and then turn on
the machine.
3. Wait until the message Permanent storage init. appears, and then release the Cancel and right
arrow buttons.
Once the cold reset process has been completed, it will either show you a 49 error or ready.
If the cold reset does not fix the 49 error then yes I agree replace the formatter.
Oct 20, 2010 | HP M2727NF Laserjet Printer
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
19 people viewed this question
Seeker5211
Seeker5211
