Question about Zyxel Wap3205 Wireless N Access Point - Ieee 802.11N Draft 300Mbps - 2 X
Firmware update on Zyxel wap3205 failed. Now the router seems to be bricked.
I try to go to http://192.168.1.2/ and there is no more gui. Also, the unit is not showing it's wireless signal on my android wifi analyzer. I tried resetting the router too...
bpcs
  • 112 Answers
SOURCE: trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Posted on Dec 29, 2007
  • 55 Answers
SOURCE: wireless conection
ok if you log into the router you can make adjustments in there.If you're unsure of it's IP address then you can find it by going to start then to run. A box should appear where you type in cmd Once you press enter on your keyboard after typing that you should see DOS appear, Black backround with white text. Once you're in there type this as you see it ipconfig then press enter on your keyboard. You should see an IP address next to default gateway. Grab a pen and write those numbers down. It may even be 192.168.0.1 Once you've written down those numbers type in exit in that same box and it should disappear. Those numbers that you wrote down should then be typed into the address bar once you open up your browser. This should take you to your router. If it asks for a password and user name, you should type in the username bit admin and the password will be either admin, password or there won't be a password so you'd leave that bit blank and then press enter on your keyboard. If none of these work then you'll have to reset the router by holding in the reset button at the back of the router for about 30 seconds. This should take it back to the factory default settings. Once you've done that turn off the router for about 10 seconds and turn it back on. Once you've done that then retype that IP address that you wrote down earlier. The reset may have reset the IP address so you may have to go back to start and do the cmd thing again and the ipconfig thing in DOS again. If the router IP address has changed then you'll see it next to the default gateway text. Then do the 192.whatever in the address bar once you've opened up your browser. Then type in admin in the username bit and either password, admin or leave it blank. Then you can reconfgure your router in the basic setup. Once you've done that, click on the word wireless and put the dot in the wpa psk section. That way you can type your own password in there but it must consist of 8 characters or more. Also make sure that you have your router set to either g or b or both so that if you add a wireless g card to another computer on your network if you have one as the cards also come in wireless b. Once you apply or save your settings, the router should restart or acknowledge the settings. Then go back to your laptop and change the password when the wireless signal has been recognised and put in the new password you created. I hope this sorts out your problem for you.
Posted on Jan 19, 2008
SOURCE: zyxel p660HW-D1 firmware update
como abro los puerto para usar emule
Posted on Apr 26, 2008
HAAi
  • 77 Answers
SOURCE: ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
Posted on May 09, 2008
SOURCE: ZyXEL p660HW-T1 V2 Blinking lights won't turn to steady on.
sdaewedqewq
Posted on Oct 24, 2008
How do i fix connection for router zyxel wap3205
Turn your DSL/cable modem off.
Turn your ZYXEL router off.
Turn your DSL/cable modem on.
Turn your ZYXEL router on.
Restart your computer.
You should now have an Internet connection.
Mar 05, 2015 | Zyxel WAP3205 Wireless Access Point -...
I'am trying to connet to the wireless interneti need the scurity net work key.
The password on the back of the router should do the trick but you must make sure that the unit eg computer, Printer, iPad are switch on and in wireless mode for it to connect and that might take a few minutes for it to pick up the signal from the router also make sure the router is not to far away from the item you are trying to connect to
Mar 02, 2015 | Zyxel WIRELESS N MULTIPLE SSID AP WRLS...
Unable to connect for setup
It could be that some other wireless device has the same IP address as the Zyxel AP. If you have not changed the Zyxel's default IP address 192.168.1.2 , I would recommend it. Try something like 192.168.1.100
Hers the link to the manual:
ftp://ftp2.zyxel.com/WAP3205_v2/user_guide/WAP3205%20v2_1.0.pdf
Mar 13, 2014 | Zyxel WAP3205v2 Wireless N300 Access Point
Zyxel wap3205 to to reset as a repeater
There is a reset switch on the back of the wap3205.
Mar 20, 2013 | Zyxel Computers & Internet
Update firmware fail
Sorry bro, I had the same issue with mine. I called tech support to no avail. After a couple of days trying to even get back into the router with no luck I gave up and got a different router. Seemed when i upgraded the firmware the file was either corrupt or something went wrong during the upgrade and it basically "bricked". I wish I could be of more help
Nov 11, 2009 | Computers & Internet
Problem trying to change the settings in my P-2602R-D1A router.
You may want to try updating your routers firmware, it seems like it's gotten scrambled. Here is a link for your routers firmware, click the 'Download' next to 'Description'
http://www.findmysoft.com/drivers/ZyXEL-P-2602RL-D1A-3-40-ADP-1-C0-340ADP1C0-firmware-driver.html
May 12, 2009 | Zyxel P660HW-D1 Router
How do you access WPA Key Settings on a ZyXEL modem?
To access Zyxel configuration/setup utility, launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.1.1 (default IP address for most Zyxel wireless devices) in your Internet browser's Location/Address bar, and then press Enter on your keyboard.
If presented with a user authentication (login) screen, try the following:
Default Username - Zyxel Wireless Router: N/A (none, leave blank)
Default Password - Zyxel Wireless Router : 1234
If you cannot login using the above, verify that (a) you are entering your password correctly, and that (b) your CAPSLOCK key is off. It could also be due to the firmware (a set of instructions stored on an EEPROM microchip) on your Zyxel product being corrupt. If so, you would need to reset your Zyxel WiFi router to its factory default settings.
IMPORTANT: Do not forget to promptly secure your Zyxel router (using a strong password, a non-obvious WEP Key, etc.) following a reset to factory default settings. Failing to do so may potentially expose your entire WLAN to scammers.
*Your vote is highly appreciated. Thanks in advance.
Dec 27, 2008 | Zyxel P660HW-D1 Router
Zyxel p660HW-D1 firmware update
Apr 25, 2008 | Zyxel P660HW-D1 Router
Zyxel Wap3205 Wireless N Access Point - Ieee 802.11N Draft 300Mbps - 2 X Logo
115 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
