Question about Canon imageCLASS MF4270 All-In-One Laser Printer
The top left corner of the paper is gettin folded over when we print sometning
5 Suggested Answers
SOURCE: canon mp530 mf printer
an explanation would have been more helpful - not all of us are still under warranty - duh
Posted on Jul 02, 2008
  • 21 Answers
SOURCE: page feed problem just started: folds top left
clean your machin.may be some object present there.
Posted on Sep 17, 2009
lserni
  • 466 Answers
SOURCE: paper feed jamms the paper all the time, will not
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Posted on Oct 27, 2009
  • 5 Answers
SOURCE: One corner of paper folds up when printing on
http://iusermanual.com/printer/canon-pixma-mx300-printer-manual.htm
this is a link to the manual, it might have something in there about it. But when that happened to me i turned it upside down and sure enough a hair clip fell out lol good luck!!
Posted on Aug 06, 2010
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Quality of printing
For the black line check the toner cartridge roller (usually covered by a movable flap) to see if there is a black line on it. If not, then check the transfer belt (looks similar to a conveyor belt) for a line (probably not black in color, possibly white or grayish). If either of these parts have a line your best option is to replace that part. You could try cleaning VERY gently with a dry lint-free cloth but this may only clear up a little of the issue.
As for the fold, try running a paper path test, usually found under test, information, or diagnostic menu option on the printer itself. Try to find anything in the paper path that may catch the paper and cause it to fold.
Hope this helps!
Nov 27, 2007 | HP Color LaserJet 2600n Printer
HP printer
Most likely worn pads & rollers, I'm afraid. Kits are available though. Not too dear.
Aug 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon imageCLASS MF4270 All-In-One Laser Printer Logo
18 people viewed this question
old marine
old marine
