Question about Sorvall Ultra Pro 80 Ultracentrifuge Centrifuge
I need the user manual to a sorvall Ultra 80 centrifuge
Sorvall Ultra 80 Ultracentrifuge Centrifuge user manual
Eppendorf Centrifuge 5430R lid does not open after pushing the 'Open' button in front display
Probably too late now but there is usually a small hole in the centrifuge where a thin shafts can be inserted to manually disengage the locking system.
Apr 19, 2014 | Science & Laboratory
How to deduce the centrifugation speed from the scale provided?
Do you have a biomedical group in your facility or somebody who's responsible for maintaining your equipment? If you do, they should have a photo-tachometer. They can place a piece of reflective tape onto the rotor to get you the true rpm speed. You probably need an accurate speed anyway to ensure proper rcf for your samples.
Dec 17, 2013 | Fisher Fischer Scientific 225 Cat...
Error 1 on the 5402 centrifuge how to repair problem
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get Error 1 and no start allowed.
To check and reprogram this EEPROM we have to acess the service routine. This is done by by jumping together pins 1 and 5 of X8 conector, on the base of the electronic board, located behind the power cable panel in the back of the centrifuge. There are about 20 setting or check parameters, but usually 1 or 2 of the described above need to be reprogrammed. Please e-mail me for details:
phdeletr@gmail.com.
Regards,
Paulo H. F. Pimenta
Dec 11, 2013 | Eppendorf 5402 Refrigerated Centrifuge
Show error 1
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get error 1 and no start allowed.
To check and reprogram this EEPROM we have to acess the service routine. This is done by by jumping together pins 1 and 5 of X8 conector, on the base of the electronic board, located behind the power cable panel in the back of the centrifuge. There are about 20 setting or check parameters, but usually 1 or 2 of the described above need to be reprogrammed. Please e-mail me for details: phdeletr@gmail.com.
Regards,
Paulo H. F. Pimenta
Dec 03, 2013 | Eppendorf 5402 Refrigerated Centrifuge
What is a Centrifuge?
Wikipedia says: A centrifuge is a piece of equipment, generally driven by an electric motor (some older models were spun by hand), that puts an object in rotation around a fixed axis, applying a force perpendicular to the axis. A centrifuge is also used to separate the components of blood in blood banks.The centrifuge works using the sedimentation principle, where the centripetal acceleration causes denser substances to separate out along the radial direction (the bottom of the tube). By the same token lighter objects will tend to move to the top (of the tube; in the rotating picture, move to the centre).
May 01, 2013 | Science & Laboratory
Manual/electrical
If Sorvall doesn't have it and an internet search doesn't help either you may be out of luck
Apr 25, 2013 | Sorvall RC-2B Centrifuge
My centrifuge 5702 rotor mentions error 3
The Eppendorf manual states that Error 3 means that there was an anomaly in the speed sensing system. The corrective action is to leave the power on with the centrifuge not spinning for several minutes and the error should clear itself.
If the error persists, then the speed sensor is probably damaged, and the unit will need to be serviced by a qualified technician.
Apr 16, 2013 | Eppendorf North America Eppendorf 5702...
Need service manual for Eppendorf 5417C Microcentrifuge
Eppendorf AG:
Please see our product page for the Eppendorf Centrifuge 5417 R. It has the manual for the Centrifuge 5417 C online as well: http://goo.gl/VCVVh.
If you have any further questions, please contact our technical support:
http://goo.gl/fmoEV
Kind regards,
Eppendorf Social Media Team
Hamburg, Germany
(socialmedia@eppendorf.de)
Oct 26, 2012 | Eppendorf 5417R Microcentrifuge
Sorvall Ultra Pro 80 Ultracentrifuge Centrifuge Logo
487 people viewed this question
Top Sorvall Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Sorvall Science and Laboratory Expert? Answer questions, earn points and help others
