Accustamp 2 refill instructions - Office Equipment & Supplies
Need a user guide for a Bissell 1761 carpet cleaner
The only 1761 on the Bissell site is a micro-fiber floor duster refill (2 refills sold for $10). https://www.bissell.com/microfiber-floor-duster-refill-2-pack-1761?utm_source=legacyredirect&utm_medium=legacyredirect&utm_campaign=%2ffloor-duster-refill-2-pack-1761%2fparts . Bissell doesn't have a manual for the refills.
This is the refill for the Bissell 1763 microfiber Hard Floor Duster. See https://www.bissell.com/microfiber-hard-floor-multi-surface-duster-1763 . The instructions for this model are available on the page. The direct link to the instructions is https://www.bissell.com/~/media/site%20us/documents/user%20guides/1763/bissell_instruction_sheet_floor_duster_1763.pdf?la=en . These instructions only include the directions for adjusting the handle length on the duster.
I hope this helps.
Aug 05, 2016 | Bissell Vacuums
Instructions on how to use holts wondarwald
Holts Wondarweld
Flush engine.
EXTERNAL CRACKS
1 Run engine until hot,drain off enough coolant to remove thermostat.
2 Remove thermostat.
3 Mix contents of can thoughoughly! and pour contents into thermostat opening.
4 Replace thermostat cover.& fill radiator with hot water,replace radiator cap.
5 Run engine at a fast idle for 15 mins,dont allow to boil.Top up if necessary.
6 Leave Wondarweld in system for 2-3 days then drain off,flush system replace thermostat and refill.
HAIRLINE CRACKS
1 MIX thoroughly and pour into cold engine (radiator if it has a cap)
2 Run engine until hot.
3 Allow engine to cool then run again until hot.
4 Follow procedure 6 above.
INTERNAL CRACKS
1 Follow external crack instructions except after pouring Wondarweld into engine remove spark plug from
affected cylinder and run engine for 20 mins. If more than one cylinder affected run for 5 minute intervals.
2 Allow engine to cool then drain cooling system and refill with clean water.
3 Drain sump & flush,refill with fresh oil.
Note:- 1/2 pint of Wondarweld for every 6 pints of water,DO NOT add antifreeze for at least 3 days after process.
Aug 05, 2012 | Cars & Trucks
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How i can refill 818 ink jet
here you can find instruction on video
for the black http://inkfilling.net/instructions-on-how-to-refill-hp-21-c9351a.html and for your colol cartridge
http://inkfilling.net/instructions-on-how-to-refill-hp-22-c9352ae.html
May 20, 2010 | HP DeskJet F380 All-In-One Printer
I want to refill toner in hp 1010 laserJet printer cartridge
If you have the manual for the printer check it, if not try checking a manual for your printer online.
Jun 06, 2009 | HP LaserJet 1010 Printer
Help me replace the ink cartridge on my photosmart copier/printer
Step 1: Turn printer on -- open front door.
Step 2: Tilt cartridge down in front and remove cartridge.
Step 4: Refill cartridge with ink per instructions on refill kit.
Step 5: Reinstall cartridge by reverse of step 2, then 1.
Works for me -- I refill 6 or more times before replacing the
cartridge.
HP 1401 PSC
Aug 29, 2008 | HP Office Equipment & Supplies
Lost instructions
I also have lost the instructions to this refill kit. Where do I drill the hole?
Feb 27, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
171 people viewed this question
jasbo
jasbo
