Question about Panasonic DVD-RV32 DVD Player
DVD RV32 displays H07
After loading a disk, it displays H07 and then STOP.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I read elsewhere that HO7 ("HOT") means that the spindle motor is getting shut down because it's too hot. This may be because it's become dried out.
I unplugged my power*, opened it up, (6-7 screws in the back and sides), then removed two screws to remove the soft disk weight that sits on top of the DVD to keep it firmly against the spindle. I also flipped a plastic switch I could see down through the platter, which allowed me to manually slide open the carousel. After that, I had access to the spindle motor. I gently turned the gears to move the laser back out of the way, then put a little WD40 where the shaft enters the motor. I manually turned the spindle about 30 times to help it seep in. It didn't help the first few times I fired it back up, but after about 3 re-boots it actually worked! That was last night, so no guarantees--and no confidence that WD40 is the appropriate lubricant for longevity, but hey, it was on it's way to the dumpster because of one stupid error, so I'm a happy camper. BTW, to test it, I only replaced the disk-weight assembly (2 screws in the plastic part covering the disk and laser).
Disclaimer: I'm not a professional. This is my experience, this is not a tutorial or recommendation. Yes, you can cut, shock, or kill yourself. Capacitors can hold a charge even when a unit is not plugged in. I have no idea what lubricant to use. Get professional help if you're not one.
Posted on Mar 31, 2014
  • Greg Nov 09, 2014
    Update: Nov. 9th, 2014. I've started getting the HO7 error again. Time to crack it open and see if I can eek out a bit more life with one more lube job.
techman
  • 3130 Answers
SOURCE: Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Posted on Jun 19, 2006
SOURCE: dvd
Could you tell me how to fix spindle by spraying silicon ? or is there any thing that I can get from Can tire to keep running and avoid the H07 message?
Posted on Jun 08, 2008
ravichetty
  • 158 Answers
SOURCE: trouble with panasonic dvd rv32
REPLACE THE SPINDLE MOTOR
Posted on Jul 27, 2009
SOURCE: I insert disk, DVD player searches, dispays H07, then STOP.
This normally means the spindle motor is faulty.
Posted on Aug 29, 2009
  • 8457 Answers
SOURCE: code h07 comes up
This is the major deffect design in the spindle motor.
Take the cover out put some WD40 in the spindle motor,leave it soak for about 20-30 mins.should work,after the motor it oil up.
Posted on Oct 19, 2009
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
I am getting an H07 code
If memory serves me well, code H07 means that spindle motor has to be replaced. It is ease enough to test, remove top cover from the unit, load DVD disk, when disk is loaded try to give it clockwise push. If unit starts and works - spindle motor is the problem, if it will not start then spindle motor plus driver IC has to be replaced.
Nov 14, 2009 | Panasonic DVD-RV32 DVD Player
Code h07 comes up when i insert a disk. i have the panasonic dvd-rv32
Oct 03, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
Dvd player not working
the dvd i have it blows the fuse what could be the problem?
Feb 03, 2009 | Panasonic DVD-RV32 DVD Player
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
