Question about Emission System for Infiniti 5 J30
Water getting in car
Water is leaking in from somewhere and all windows and doors are closed tight. floor is wet. Can you help
  • 30 Answers
If the front footwells are getting wet it is possible that the heater core is leaking .Are you losing radiator coolant? the other possibility is the air con drain tube is blocked or fallen off.
Posted on Feb 12, 2014
All floor carpet gets wet when it rains
Get in the car and have someone flood the outside of the car with a water hose (no nozzle). Watch for leaks. Check all window seam, door jambs, etc. Water can travel quite a ways before becoming visible so do t be surprised if the leak is somewhere other than where the majority of the water is.
Jul 26, 2016 | 2007 Volkswagen New Beetle
Wet driver side floor
I used to get water in my trunk when it rained hard. I re-caulked the rear window and it stopped. A water leak has a capillary effect meaning it will follow ridge lines and can appear in unlikely areas after it flows downward. I sometimes get water on my driver side door when I wash the car and spray sideways to rinse. I would check all your rubber seals around the windshields and doors.
Mar 24, 2014 | 1995 Buick Park Avenue
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Interior floors are wet
This problem can be cause by several things here are the list
1. check water leaks from door windows gaskets
2. (if sunroof) check for leaks
3. air conditionins evaporator can be clogged
good luck
Dec 28, 2009 | 1987 Honda Accord
2007 Civic EX...found the carpet wet...I dried this out and after rain, it is wet again. It is not the slanted part behingd the brake pedal. It is the flat part of the floor...driver's side.
Sometimes tough to find. If it only gets wet when driving, the problem could be in the floor pan...possibly a rubber stopper missing. If it happens when it rains without driving, may be in a door seal or coming thru the windshield gasket. Water leaks also can come in on one side and follow other objects then drip somewhere else, (because of surface tension). You can take a water hose and wet one section at a time to try and narrow down the source of the leak. Has the car had body work done? If so, look at the repaired area. Look at rubber seals around the doors and windows. Good Luck! I hope you find this to be very helpful!
Dec 07, 2009 | 1996 Honda Civic
Water in pass. side floor
Check your firewall between front psngr side and engine bay and psngr side fender. Check If there is no leak from you windshield or window, then your floor board might have a hole in it too. Simple window/door leak check, (preferrably at night) have someone who smokes cigarettes sit in the psngr side with all the windows closed and have him him/her blow smoke towards the windshield, window, and towards the middle of the 2 doors. If you want to put the fan in the car as well do it but car will stink more. While you stand outside and see if smoke is coming out. Hope this helps.
Oct 02, 2009 | Pontiac Grand Prix Cars & Trucks
Floor behind driver seat is wet.
For sure there's a leak somewhere.
check if there's no damage or defects in the door rubbers, check if you can find another wet areas to help you find the leak.
There's a few holes in the floor covered with plastic caps, check if there some missing and if they're not damaged.
May 02, 2009 | 2003 Kia Spectra
Water leaks into my BMW 325i
Check your outer door window seals. If they are worn water will leak through the door to the floor.
Apr 22, 2009 | 2001 BMW 325
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Vehicle Parts & Accessories Logo
59 people viewed this question
Top Infiniti Vehicle Parts & Accessories Experts
advance tire and...
Level 1 Expert
tjonesauto
tjonesauto
Tom Chichester
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
