Question about Philips AJ3935 Clock Radio
I can't get the alarm OFF pm and onto am - Philips AJ3935 Clock Radio
How to set alarm am and pm
Scroll the time wheel to set the alarm time.
  1. Enter the alarm time manually by scrolling the hour (or minutes) field.
  2. Scroll to AM or PM to set for morning or afternoon.
Dec 02, 2015 | Audio Players & Recorders
How do I get my smiggle alarm clock to ring at a.m and not p.m
There is usually a 'PM' indicator on the alarm screen to indicate when the alarm is in pm. You hold down the alarm key to set the alarm.
Mar 31, 2015 | Audio Players & Recorders
How to set alarm for am or pm
Which phone are you using.?
If you are not getting any am or pm option your phone settings might be set to 24 hours timing setting. So in this you can set using 24 hour watch conventions. E.g if you want to set alarm for 5 pm you can set as 12+5 =17 so 17pm
Oct 15, 2014 | Cell Phones
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
Samsung Galaxy S4--Alarm Clock Issue
Take it back and get your money back as there is obviously a problem with that unit. Try a different brand.
May 23, 2013 | Samsung Cell Phones
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
Seting up the alarm
when you time or" set exm - 3:00 pm type in 15 this is train time. then goes to pm.
May 30, 2012 | Audiovox Audio Players & Recorders
How do i change the alarm time from pm to am? its not in the manuel.
http://www.lg.com/us/mobile-phones/LG-GT365-Aqua-Blue.jsp
Above is a link to your phones manual in case you ever need it if you lose the one that you have.
Time: Select the desired set time mode
using the navigation key. Input your desired
alarm time by specifying the hour and
minutes. If the time is in the 12 hour format,
you have to select either 'am' or 'pm' using
the Center key.(its just your select key)
(Repeat: Select the desired repeat mode
using the navigation key.)
Alarm Type: Allows you to choose an
Alarm type for your selected alarm.
Options are: Follow Profile/ Always Sound/
Always Vibrate.
Alarm Tone: Select the alarm sound to use
for the alarm using the Center key
This is actually found on page 65 of your manual.
I hope this helps you out. just select the format, am, pm or 24 hours like you would the time you want to change the hour or mins, .
I hope this helps you. please let me know
May 14, 2011 | LG Neon GT365 Cell Phone
Setting the Alarm
After you set the time on your alarm, if the icon out to the side of it is am & you want pm, press the - button on the very top left hand corner & it will switch to pm. Vice Versa if the icon out to the side is pm & you want am
Jan 11, 2008 | Pantech C120 Cellular Phone
Time and alarm same meridiem
this is a glitch in his product.
Jan 09, 2008 | RCA RS2046 Shelf System
Philips AJ3935 Clock Radio Logo
21 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
