Question about Maytag MDB4409PAW Built In Dishwashers
Maytag Dishwasher Not draining and blowing fuse
Dishwasher not draining. Cleaned drain tube out - not the problem. Dishwasher runs and blows fuse (circuit breaker) Any ideas? What can I check next? Any common problems with this model? Thanks!
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: Maytag Dishwasher won't drain
remove the plug in the garbage deposal
Posted on May 06, 2009
  • 3600 Answers
SOURCE: Our dishwasher does not drain all the way. What could be the problem?
water pump is defective replace the pump about $40.00 and is not to hard to do. Take a picture of the washer underneath and send me a pick and I will give you the exact details of how to remove and replace it.
Posted on May 24, 2009
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
Daniel S
  • 4323 Answers
SOURCE: Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
I have a maytag portable air conditioner. It has a little black drain tube with a plug. It seems to have more water than the drain can handle and overflows what can I do
Remove the black drain tube and clean the ac where tube connects and blow air through black drain tube make sure there is no blockage in tube.
Sep 19, 2015 | Maytag Heating & Cooling
The bi-metal fuse keeps blowing on my dishwasher and it hasn't drained properly
youre motor is straining .this can cause a electricle fire call service man asap do not use this is unsafe
Mar 21, 2013 | Dishwashers
Maytag dishwasher will not drain
Drain Tube could be clogged....Have you disconnected the outlet drain tube from the motor to the disposal/sink/drain?
Aug 11, 2010 | Maytag MDB5100A Dishwasher
My fedders portale a/c does not drain. The water is not draining from the top compartment
Try blowing into drain tube sounds like a blockage. If no tube take off cover and clean out weep holes.
Jun 23, 2010 | Maytag Portable Air Conditioner M6P09S2B
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
Maytag Mah6700. Not filling/ draining simutaneously=NO CYCLE
try to blow through the pressure switch hose back into the tub and if you have a piece of same size hose when you disconnect the tube to blow through it use you spare hose connect to the pressure switch and blow lightly do you here a light clicking when you blow into it if not pressure switch is more than likely failed when you done tested air restrictions ........RECONNECT THE TUBE TO THE PRESSURE SWITCH.....
Aug 25, 2009 | Maytag Washing Machines
Dishwasher does not drain
The drain runs from the dishwasher into either the side of your garbage disposal, or directly into your sink drain. If it is running to your disposal, pull the hose and make sure that the plug in the disposal (where the hose connects) is knocked out. Some have been known to install them without removing the plug. Either way, pull the hose loose and you can use a compressor to blow through it. If the air comes back through the dishwasher, then you are probably blocked in the main drain.
Jun 22, 2009 | Maytag 24" Tall Tub Portable Dishwasher -...
Maytag dishwasher not draining completely
You have to remove the bottom kickplate to gain access to the drain pump and drain hose. You can remove the drain hose and blow through to see if the obstruction is in the hose. Take a look at the check valve for blockage. If a garbage disposal was just installed, make sure the knockout plug was removed.
Feb 25, 2009 | Maytag 24 in. MDBH940AW Built-in...
Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
May 30, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Maytag MDB4409PAW Built In Dishwashers Logo
23 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
