Question about Frigidaire Kitchen Ranges
Gas burners go out
Kenmore elite dual fuel range C970 burners spontaneously go out while cooking. All of the burners do this at all settings below medium but only intermittently. We have adjusted the gas flow several times, changed the regulator and computer control pad, blew out gas line coming into stove, had gas company out twice to check gas line and regulator on gas meter. Everything seems to be ok but the burners still go out on their own. What else can we try?
  • Jerry Kramer
    Jerry Kramer Feb 12, 2014
    Hi Cherie Reglin, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is there any sort of a draft that could get to the stove? Ceiling fan, close heating/air conditioning vent, window or door that gets opened frequently?
  • Cherie Reglin
    Cherie Reglin Feb 13, 2014
    No drafts, not from windows or ceiling fans etc. problem occurs in summer (when windows are open constantly), winter (window never open) and all year long. The burners stay on and work normally +/-70% of the time. It seems that when the outdoor air pressure drops (due to weather fluctuations) the burners go out...
Kgt1962
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
protek480
  • 1723 Answers
SOURCE: Why does the surface burners and broiler light but
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Posted on Sep 11, 2009
milten1
  • 1304 Answers
SOURCE: Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Posted on Oct 05, 2009
  • 949 Answers
SOURCE: i have a kenmore elite slide in range. we notice the smell of gas
There could be a couple things that would cause your symptoms, I will do my best to try and explain each one.
First off I am assuming from your dialog that everything is cooking the same on the top and in the oven, the times are the same the flames on the top burners look or sound no different. If this is the case the repair outside would not have a direct bearing on a 'problem' but it could cause the odor. Here is why...
Natural gas has no odor a chemical called Mercaptan is added to the gas to make a leak easier to detect. The amount of Mercaptan is regulated closely so it all is consumed in the flame. If there is too much you will get an odor from the flame.
The Mercaptan can line the inside of the piping that feeds gas from the regulator to the range. Working on the pipes can break loose some residue that may have a stronger presence of odorant causing you to smell it for some time. It will eventually go away.
The second thing that could cause this odor is if you have done any remodeling in the home, paint fumes, stains, oils many other chemicals can mix with the gas and cause this Mercaptan to not be burned up all the way and create an odor.
I hope this helps
Posted on May 21, 2010
national_a_r
  • 148 Answers
SOURCE: I have a GE JGSP33
Yes, your oven igniter is bad here is the part#WB13T10001
Have a great day!
Posted on Dec 08, 2010
Testimonial: "g"
Elite dual fuel range/oven. Why isn't it heating past 100 deg and burner igniters do not spark?
sadly it sounds like you need to call a service repairman . being an appliance that can explode I do not suggest you try and fix it yourself .
Oct 27, 2015 | Kenmore 30" Slide-In Dual Fuel Range...
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Won't heat all settings
Locked cook-top? Check breaker, fuses, plug
Jan 03, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Kenmore elite dual fuel range - all burners' igniters are clicking without being in use /trying to ignite the burners
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 06, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
Kitchen Ranges Logo
44 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
