Question about Toshiba 46XV640U 46 in TV
I need 4 screws for the pedestal assembly, can you thee me the size?
Screw size (diameter x length x thread type)
4 Suggested Answers
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
  • 39 Answers
SOURCE: wrong screws
Hey there,
The screws for the tv are metric.
I would suggest the screws supplied with the shelf are not metric.
Try some new ones.
Posted on Sep 13, 2009
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Posted on Jan 14, 2011
Which type of screws
Usually you rummage through your old screw dish/box and find one that fits. Threads for plastic - course. Threads for metal - fine. Check the length.
Aug 20, 2014 | Computers & Internet
I need a missing screw for my baby crib the name for the screw in the manual factory in screw JBC 06x16mm is a Carter crib.. i hope u hear about ya soon.. thanks
You can get this screw at any hardware store.the dimensions you listed dictate the exact size and thread you need. The first number is the size of the screw (diameter, in this case in millimeters). And the second number is the pitch of the threads on the screw. Pitch is the distance between one thread to the next thread in short (in millimeters in this case). The only other thing you would need is the length. In short any 6mm X 16mm screw will do so long as you have the right length as the screw will come in many lengths.
Regards, Tony
Apr 13, 2011 | Toys
Im looking for the thread size, off the drive shaft of a power build 10.5 hp
i'm assuming your looking for the nut that holds on the flywheel? if so, measure the diameter of the thread in the crankshaft. you need the diameter and pitch(oor threads per inch) to "know" the thread size. Measure the diameter accurately. then, measure the length of the thread. example, if there is 1/2 inch of thread length and you have 4 threads in that length it is a "8" thread. so if the diameter (overall diameter measured on top of the tips of the thread) is 1/2 inch, then your thread is 1/2-8.
Jan 14, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have a coleman powermate 6250 I need to remove the armature so I can change the oil seal on the crank. How do you remove this
Here is how I did it. First unscrew the bolt holding the armature to the crank. Measure the bolt length and thread sizing(mine was 5/16-24) Go to menard's or any hardware store and buy a piece of un-threaded rod the same diameter. Buy a die so you can thread the end of the rod. cut the rod one inch shorter than the bolt length and make a kerf in the end for a screw driver blade. Now measure the inside diameter of the armeture hole( mine was 3/8) I then took a 7/16 tap and threaded the end of the armeture. Now screw in the rod you made, then screw a bolt into the end of the armeture and this will push the armeture off the crank without damaging it.
Dec 06, 2009 | Coleman Powermate Premium Plus 6250W...
Missing pedestal screws for 3000 series 42 inch LCD. model 42PFL3704D
I just received the same TV (Philips 42PFL3704D/F7) in a box...with no screws to mount the pedestal to the TV. What size screws do I need to buy??
Jul 07, 2009 | Philips 42PFL3704D LCD TV
Has no mounting screws what type do they take or are they standard
Most of these tv's use the 1/4-20 machine screw, for example, has 20 threads per inch and a 1/4 inch diameter. I would recommend that you stick a piece of wire into the screw hole to determine the length that you need and start with this size screw. If it fits nicele and snugs down you will know you have the correct size.
May 07, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Need screw size for Bose 901 Lifestyle speaker to mount to PS6's
Had the same question, e-mailed Bose support and they suggested "# 10 woodscrew, 4.5 mm diameter".
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
HP speaker
The screws are little fatties,
they measure 3/inch in height and 1/4 inch in diameter...
just measured them for you!!!
hope this helps!!
Nov 17, 2008 | HP PL4260N 42 in. Plasma HDTV
Toshiba 46XV640U 46 in TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
