Question about Texas Instruments TI-15 Explorer Calculator
Sine, Cosign, Tangent
Can you figure Sine, cosign and tangent on the TI-15?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Not directly. The calculator does not have the trig functions built in. You could do it the same way people did it before pocket calculators.
Posted on Feb 12, 2014
3 Suggested Answers
  • 4 Answers
SOURCE: Sine, Cosine, Tangent buttons malfunctioning
you're in radians...
go to MODE
scroll down twice
hit the right button
then hit enter...  :)
Posted on May 18, 2009
  • 6 Answers
SOURCE: on my TI 83 plus my sine cosine and tangent
Alot of people seem to be having this problem. Angles can be measured in two units, degrees and radians. Your calculator is currently doing everything in terms of radians. I have an 84 but I'm sure the 83 is similar, go under MODE and look for Degrees and Radians and make sure you choose degrees. if you have to convert, 360[degrees] = 2* pi [radians]
(easy to remember, 360deg in a circle, 2pi radians in a circle)
Good luck
Posted on Aug 12, 2009
When ever i press sin^-1, and type in a number, the answer is always "domain error" on my ti 30x iis, how can I fix this problem?
Not quite true. (Explanation at the end)
The sine and cosine of an angle have values in the closed interval [-1,1]. That means whatever the value of the angle, its sine or its cosine cannot be less than -1 or greater than 1.
When you consider the inverse problem where you want to find the angle whose sine or cosine is known, you must take the values of the sine or cosine in the interval [-1,1]. That is the domain of the functions arc sine and arc cosine. So if you take a value outside the domain [-1,1], and want to calculate the angle to which it belongs, the calculator signals that there a domain error, because there is no angle that answers the question. Limit the arguments of the sin^-1 and cos^-1 to values in [-1,1]
For the inverses of arc tangent and arc cotangent functions there is no domain limitation because the range of tangent and cotangent is the whole real line ]-infinity, +infinity[.
Mar 30, 2014 | Office Equipment & Supplies
Can I figure Sine, Cosine and Tangent on my TI-15?
Not directly. The calculator does not have the trig functions built in. You could do it the same way people did it before pocket calculators, but you can't do it just be pushing one or two keys on this calculator.
Feb 12, 2014 | Texas Instruments TI-15 Explorer...
Sharp el-501w figure degree on rise run seven inch rise tweve inch run = ? degree
If you have learned about the trigonometric ratios (sine, cosine and tangent) you can use the tangent of the angle.
Let your run be to the right ( along the positive x-axis) and the rise be upwards along the positive y-axis. The tangent of the angle is
tan (theta)=rise/run=7.5/12
If the calculator is set with angle unit in degrees, the angle is obtained as the arc tangent of the (rise/run) value.
theta= arctan(7.5/12)=32.00538321 or about 32 degrees.
The arctan is the inverse of tan. To access it on the calculator press [2nd F][tan]
Depending on the calculator (sorry I do not have your model under my eyes)
Press [2nd F][tan] ( 7.5/12) [=]
or
7.5/12 = then [2nd F][tan] [ALPHA][Ans] [=]
Jan 21, 2012 | Sharp Office Equipment & Supplies
I can't seem to be able to figure out how to find the cosine tangent or sine of an angle...Help?
Unlike traditional calculators, the FX9750G uses textbook order to call functions. For example, to calculate the sine of 45°, you key in (angle argument unit set to degrees assumed):
[sin] 45 [EXE]
Cosine and tangent are analogous. Argument format can be degrees, radians or grad. You can set up the angle argument unit by keying in:
[SHIFT] [SETUP] [v] [v] [v] [v] and then
  • [F1] (Deg) [EXIT] for degrees (1 full circle = 360°),
  • [F2] (Rad) [EXIT] for radians (1 full circle = 2pi),
  • [F3] (Grad) [EXIT] for grad (1 full circle = 400 gon).
Jan 07, 2011 | Casio FX9750GII Graphic Calculator
Ive been doing inverse sine, inverse cosine, and inverse tangent problems for a few hours now but all of a sudden when i put in this one problem it gives me: ERR:DOMAIN. im not sure what is wrong... I've...
Since you are familiar with sines, cosines, you know that their ranges (interval of values) varies from -1 to 1. The inverse functions of sine and cosine tkae their values in that very domain, [-1,1].
However you fed the arc sine function (sin^-1) a vlaue of (25/20.48) and that value is obviously larger outside the [-1,1] domain, hence the DOMAIN error message.
No such domain limitations exist for arc tangent (tan^-1) because the range of the tangent function spans the open interval ]negative infinity to positive infinity[.
Nov 02, 2010 | Texas Instruments TI-84 Plus Silver...
Find length of right triangle given one angle an one length
Formulas relating to right angled triangles are:
Sine = perpendicular divided by hypotenuse
Cosine = base divided by hypotenuse
Tangent = perpendicular divided by base
Sine Tangent and Cosine functions are all available in Excel
Aug 08, 2010 | Microsoft Excel for PC
My casio calculator cfx is coming up with 'syn error' everytime I type in a sine cosin or tangent problem
I believe you are not pressing the keys in the right order.
If you know how to set angle unit, skip this part and go to Exemples
If you want to calculate the sine , cosine or tangent of an angle given in degrees, the calculator must have the angle unit set to degrees. To do so :Turn calculator ON, scroll to [RUN] icon and press [EXE] then [SHIFT][SETUP]. On the fifth line angle must be set Degrees. If it is not in degrees, press the key correspondig to menu deg (F1)
(If you have to use the Radian as unit of angle, that is where you set it.)
So your angle is in degrees.
Exemples
To calculate the sine of 15 degrees press [SIN] 15 [EXE].
If expression inside the sine is complicated or contains diverse operations use parentheses as in the exemple
[SIN] [(] 90/2 -180/3 [)] [EXE].
You proceed the same way for cosine, or tangent.
Hope it helps.
Aug 31, 2009 | Casio CFX 9850GB Plus Calculator
go to MODE
scroll down twice
May 16, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-15 Explorer Calculator Logo
56 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
