Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
I have a Wurlitzer, "One More Time 1015" , model OMT1015CD, Serial # 44045067. When i enter a cd, it picks the cd places it down then tuns a little bit and stops continously for a little bit, no sound, then places the cd back. What do i need to fix this problem?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The laser unit is faulty. Contact dave@Wurlitzer.co.uk who has a repair service.
Posted on May 07, 2014
SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Posted on Aug 25, 2008
  • 195 Answers
SOURCE: how do i move my wurlitzer 1015 cd one more time
I take it you wish to transport your jukebox.
If this is the case I would remove all the CD's (keep them in the order that they were on the jukebox for installation again)
The jukebox mechanism will have some form of tie down system that locks down the mechanism tight into cabinet.
Check the power supply, amplifier etc to see if they pull off their mounts. If they do usually on these parts are holes to insert wood screws to lock them down (use the correct length of screw so they do not damage the cabinet) On the title racks or tubes tape them down so they do not come loose in the cabinet.
Try if at possible to transport the jukebox upright in or on the vehical, cover the jukebox with blankets before strapping to the vehical.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 38 Answers
SOURCE: Wurlitzer arm frozen w/ one digit flashing 8 then E w/o top of E
The WURLITZER CD JUKEBOX MODEL CD1 THREW CD8 HAD MECHANISEM THAT STOPPED DUE TO LACK OF LUBRICATION. TO FIND OUT IF THIS IS YOUR PROBLEM. FIRST THING TO DO,PULL THE 120 VOLT CABLE OUT OF THE WALL SOCKET. THAT WAY YOU WILL NOT GET HURT.
THERE ARE TWO MOTORS NEAR THE RECORD MAGAZINE, BELOW THE TURNTABLE.
EACH MOTOR HAS A KNOB ON THE REAR OF EACH MOTOR. TURN THAT KNOB A COUPLE
OF REVOLUTION, CLOCKWISE THEN COUNTER CLOCKWISE.
DO BOTH TURN FREELY??, OR IS THERE A BIND ON ONE MOTOR.
DOCTOR FIX
SEYLEVITT@JUNO.COM
Posted on Jul 21, 2009
  • 38 Answers
SOURCE: My jukebox doesn't play
DOCTOR-FIXCAN MAKE A COPY FROM MY ORIGINAL. MOST LIKELY YOUR PROBLEM IS THE LIGHT THAT COUNTS AS EACH CD PASSES. LOOK BETWEEN CD CAROUSEL, AND CD GRIPPER ARM. A CD MAY HAVE HIT THE METAL LEAVER THAT THE LAMP,
IS ATTACHED TO. YOU HAVE TO GET DOWN 0N IT WITH A MIRROR TO SEE THE LAMP, AND SEE IF THE METAL LEAVER IS NOT BENT. FOR COPY OF WURLITZER MANUAL, A CD RECORD PROBABLY HIT THE LAMP. 636 2273300. NAME IS SEYMOUR LEVITT COMPANY NAME IN-HOME JUKEBOX REPAIR. SEYLEVITT@JUNO.COM THIS IS A COMMON REPAIR PROBLEM. GOOD LUCK.
Posted on Dec 01, 2009
  • 211 Answers
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
This is a laser unit fault or the pcb under the laser unit. Both are expensive.
Posted on May 26, 2010
I own a Wurlitzer 1015 100cd machine that when turned on flashes number 8 , picks up the CD selected, places it on the CD player which does not turn and after a short while returns it back in its slot....
It is a faulty "actuator switch" for the microswitch K7. Look at the base of the gripper .....follow that rod backwards towards the gearbox and you will see a little sticker saying K7. There is a microswitch activated by a 'duckbill' bracket. Either the bracket has slipped or it is broken, or K7 is faulty.
Wait until the cd has been placed back in the carousel then press on K& and if it the carousel rotates to the next selection...there's the problem.
In a new machine there is a Allen key for tightening that bracket.
Jun 13, 2012 | Wurlitzer Jukebox 1015 One More Time...
I HAVE A WURLITZER 1015 JUKEBOX ,WHEN I PICK A CD IT JUST PICKS UP THE CD PUTS IT ON THE PLAYER AND RETURNS IT TO THE TRAY AND KEEPS DOING THE SAME THING OVER AND OVER
This can be caused by several different factors....If you will email me, I'll give you my phone number so I can help you further troubleshoot your problem. Please email tech@wurlitzer-ohio.com.
Mar 11, 2011 | Wurlitzer Jukebox 1015 One More Time...
My 1015 will selects the same disc, then places it on the turntable. Turntable does not spin. The arm the picks the cd and places it back into it's slot. This happens continuously and the digital display...
There is most likely a problem with your K7 switch acuator. I have these in stock, and can help verify this with you over the phone. Please email me and I'll give you my phone number, tech@wurlitzer-ohio.com
Mar 06, 2011 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a 1993 wurlitzer New York, New York jukebox. it has the same inters as a 1015 one more time. the problem i am having is with the cd gripper arm. it will take a cd from the cd carousal and place it...
I would suspect you have a lubrication (or more specifically lack of lubrication) problem. When the gripper arm is over the carrier, pick it up a couple of inches (as it moves to pickup a CD) and drop it. It should snap right back down. If it doesn't, it will not properly pickup and return CDs. You may be able to lubricate it to get it working again. For further information, you may email me, tech@wurlitzer-ohio.com.
Mar 15, 2010 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
I've a wurlitzer 1015 and can i connect an ext. pick-up player??
.You can if you ue a "background music adaptor" which allows a second source of music to be played through the amp.
Dave F.
Apr 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
140 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
