Question about NEC M260X LCD Projector
Amber light won't turn on
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com
The System / Motherboard has faulty Power Circuit. Contact HP and arrange a repair. If under warranty won't cost anything.
Jul 05, 2012 | HP 530 Notebook
Won't turn on Vizio light is amber
Could have faulty capacitors in the power supply. Are you brave enough to open up the unit and take a peak??
May 10, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Computer won't start. PSU good. Amber light on mobo. What gives?
It is probabley the power supply is bad the amber light should be green Get yourself another power supply and see if that don't fix your problem
Sep 01, 2011 | Dell Dimension 4300S (Refurbished)...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Turns the power button on and the power light keeps blinking in and out and the computer won;t come on
I would look into testing the laptop by taking out the battery and plugging in solely the charger, and try turning it on. If it doesn't work, it sounds like it can probably be an issue with the Motherboard or the RAM.
Is the blinking light an amber or green color? If amber, then it might be a RAM issue. If green, the power would be on, but the monitor might not be active/working.
Apr 03, 2011 | Acer Aspire AS7741-7870 Notebook PC and...
NEC M260X LCD Projector Logo
23 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
