Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 3105v programming - 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 3105v car alarm has been hacked ,what do I do now?
without knowing more details about what exactly you mean by "hacked"...the best I can suggest is to remove the unit and return to stock wiring...
If you need further help, reach me via phone at https://www.6ya.com/expert/jonathan_4cd718ed254374ee
May 30, 2016 | Viper Vehicle Parts & Accessories
Viper Alarm 3105V. Why are both arm and disarm doing the same thing?
It is probably best to consult with the manufacturer or supplier in matters such as this Mr Garcia, they will probably have specific knowledge about that unit that is not widely circulated.
It may be a faulty remote or the unit itself but will probably need to be diagnosed in the presence of a technician with familiarity of that model.
GOOD LUCK
Aug 09, 2015 | Viper Vehicle Parts & Accessories
How do I program my viper replacement transmitter for my car.
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
Dec 12, 2014 | Viper Vehicle Parts & Accessories
Program remote
get in vehicle turn key on with new key fob in car, let run for 20 or so then turn off . hit the unlock button it should be programmed but not promising anything lol
Sep 30, 2013 | VIPER 7141V VIPER 4BUTTON REMOTE 7141V
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
May 17, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
292 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
