My printer broke down. As electrician I moved the plastic cover. The gear for the Maintenance kit was broken off on the 3 places where it was screwed on. Errorcode as described. I repaired it by placing new screws, and it fits perfect. Now the printer boots correct, tests the gear ok, but stops with the same errorcode. Hope not to recycle the printer already at 45.000 pages. I know Service Mode, and the tests are running, and stops at the same code. But what does it mean?
There are no screws for the maintenance kit. if you are taking about the gear assembly with the motor, there are 3 places where the screws go in, however just replacing the screws does not hold that part properly. there is a kit for that, also you might have a damaged dm camshaft.
once you get the printer fixed, and you buy named brand ink, we can get your printer back to warranty, feel free to ask
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
