Question about LG SecurDisc 8x External Double-Layer DVD RW/CD-RW Super Multi Drive
Doesn't Recognize Disc
GP08LU10
DVD Player doesn't recognize disks present
Get a DVD cleaning kit and follow instructions, if this fails the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to buy.
May 08, 2012 | Yamaha DV-C6480 Multi-disc DVD Player
Lost install disc
did you try looking on line?get driver download
Dec 31, 2011 | LG GP08LU10 8x DVD RW DL USB 20 Slim...
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
I put in a blu ray disc but it is not playing in any media player and the disc drives do not recognise that a disc has been entered
Unless the drive in your laptop is a blu-ray drive, it won't recognize a blu-ray disc. A blu-ray drive can recognize and play a regular DVD, but it doesn't work the other way around.
If your computer is indeed fitted with a blu-ray drive, the laser lens may need cleaning. On a laptop, you usually have clear access to the lens with the tray open, so you can try cleaning it with a cotton swab moistened with lens cleaner. Or the disc itself may have a problem. Try another disc and see if the trouble continues.
If the computer doesn't have a blu-ray drive and you will frequently want to play blu-ray discs, get a USB external blu-ray drive. It's easier to find one of those than to locate a suitable blu-ray replacement drive for a laptop. There are many variations of drives used in laptops, but an external drive will always be compatible. And you'll be able to use it with other computers not blu-ray equipped.
Apr 23, 2011 | Acer Computers & Internet
LG GP08LU10 Copied DVD Playback Problem
I would do either of 2 things. First, check the LG site for any firmware updates that apply to your model and apply them
Second, try using a CD cleaner kit to be sure any dust on the laser is removed. These usually involve a cleaning disc and aren't common, but do exist. They use a static charges surface that lifts dust from your DVD read/write head and the platter.
Mar 14, 2010 | LG GP08LU10 DVD-RAM Burner
Driver download
where did you find the driver download for the lg gp08lu10? The official LG website doesn't have one!
Sep 13, 2009 | LG SecurDisc 8x External Double-Layer DVD...
Vista/usb problem doesn''t run
You may have to load it manually through control panel with the disc..sometimes Vista/XP may not recognize the device during plug and play..if you have any questions let me know
Mar 27, 2009 | HP Office Equipment & Supplies
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
LG SecurDisc 8x External Double-Layer DVD RW/CD-RW Super Multi Drive Logo
26 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
