Question about Compucessory Wireless Mouse 2.4G 2-1/4"x3-3/4"x1-1/2" Black/Blue - CCS30226
Wireless mouse not working
Mouse not working.
Wireless connection stopped working mouse is wireless also working great I went thru all the steps to set up wireless again and still is not working
Are you sure the mouse is working on the same device as the connection with your camera? I guess you are talking about the wireless connection between your PC and Camera.
For a wireless mouse you are using a wireless dongel. A very small usb dongel. Or when you have a MAC the wireless mouse is connected via a dedicated receiver. Setting uo wireless can be for your Wlan, Camera, Keyboard, Mouse and so on. The network uses ip addresses in a certain range. your camera should be working with IP too, but the mouse uses a different protocol and does not work on your network at all.
The only thing these wireless things have in common is they use radio waves. protocols are different. So a working mouse is no guaranty your network or camera is configured correct. Nor a guaranty your switches or routers are working correct.
Please try to describe exact what is working and what is not working. Perhaps you still remember when something went wrong.
Oct 29, 2013 | Cameras
Mouse not working wireless only with pc plug in. Mouse is Cherry Ergo Shark-R
On my Logitech wireless mouse, when the battery runs low, it stops working. Also if your keyboard is wireless the batteries in that could affect the operation of the mouse. Plus, on another brand wireless mouse the signal from the usb port adaptore for the mouse was being blocked because i didn't have the mouse clear and to far away. Hope these tips help.
May 28, 2012 | Computers & Internet
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
No mouse control via wireless mouse, or touch pad
IT SOUNDS LIKE YOU HAVE MAY HAVE DRIVERS OR IRQ THAT ARE CONFLICTING, TRY UNINSTALLING THE DRIVERS FOR YOUR WIRELESS MOUSE, AND REINSTALLING THEM, MAKE SURE THE WIRELESS MOUSE IS UNHOOKED BEFORE YOU REINSTALL THE DRIVERS.
Mar 11, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
Wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Oct 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
GE Wireless mouse & keyboard
are both keyboard and mouse communicating with a single wireless devices, or each has it's own? sometime you need to sync the signal to the wireless device. but do this first... ask your sister if the mouse was working before she gave it to you, there is a possibility that the mouse is broken/no working. if it's an optical mouse, the mouse that has lights sensor, make sure it lights up...
Feb 16, 2008 | GE Wireless Optical Mini Mouse 3087897985
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
Compucessory Wireless Mouse 2.4G 2-1/4"x3-3/4"x1-1/2" Black/Blue - CCS30226 Logo
Top Compucessory Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
anthony alagon
anthony alagon
Are you a Compucessory Computer and Internet Expert? Answer questions, earn points and help others
