Question about Soyo Computers & Internet
I have a TechAid Card. When I put it on a AsRock motherboard it gives me the next message: dO, b3 and FF. It still keep flashing me the message and after a while the motherboard turns off. What can I
The motherboard oes not turn on. After that I put the TechAid diagnostic card in it and turn it on. Then it gives me the message: dO, b3,and FF. The motherboard stays on for a while flashing the above mensioned message and then the motherboard turned off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Soyo Master
  • 2,226 Answers
You need to read what the manual so you can work it out you have three codes to fix first before it will work
Posted on Apr 23, 2014
  • 12 Answers
SOURCE: foxconn 925xe motherboard
first check wheather power cable is join correcly at the monitor
then check video card placed correcly in agp card
or see the monitor cable join correctly at pc
Posted on Dec 07, 2007
SOURCE: Computer turns on, but there is no display on monitor.
Go to the BIOS in Advanced - Chipset
Change the Graphic Adapter Priority setting.
Posted on Aug 02, 2008
degcomputers
  • 13 Answers
SOURCE: Upgrading graphics card onto gx280 motherboard
You need to find a "PCI Express" video card. Your Motherboard does not have an AGP slot. There are lots of them to choose from. Better to pay more now and get more memory on the video card than to regret the purchase and buy another one. IMHO
Posted on Jan 18, 2009
  • 67 Answers
SOURCE: asrock p4i45gv not detecting hd 3650 agp card
Take the new card out and reconnect the monitor to the on-board VGA. Boot up press F2 and enter the bios. Look for resource configuration and set the Primary Graphics Adapter as AGP.
Save and switch off. Disconnect the PC from the mains, fit the new card and attach the monitor cable to the new card.
Make sure to attch a power connecter to the card if it needs it.
Reconnect the PC to the mains switch on and hopefully away you go.
Best of luck.
Posted on Jan 29, 2010
  • 366 Answers
SOURCE: My computer crashed and when I try to diagnostic the problem with the TechAID diagnostic Card of Soyo, it tells me that FF is not functioning. After that I bougt a new processor for socket 775 and I t
sounds like a faulty motherboard. try testing the motherboard after removing everything apart from the cpu and ram then add one piece at a time to eliminate one thing at a time.
Posted on Feb 14, 2014
Where can I find the network card driver for gamer extreme NE721i on windows 7?
start > control panel> device manager> network adapters...
next WRITE DOWN the adapter info
on internet access computer, download the driver files to a flash drive, install them on your machine from the flash drive. be certain to check operating system compatability when selecting which driver package to download.
Jun 26, 2014 | iBuyPower Gamer Extreme NE721i Desktop PC...
AsRock Motherboard
First of all, not all the time memory is bad it gives a beep. So you might still want to verify that it's not the memory. Try the memory in another cpu or try another memory in your cpu.
If you have verified that the memory is not the issue, then your next culprit is the video card. Make sure the video card is working. Take it out and clean the contacts with a clean piece of cloth and then reseat it properly.
Please let me know when you have verified the above recommendation and if it works or not.
Thanks and good luck
Lolita
Dec 14, 2007 | Asrock AM2NF6G-VSTA Motherboard
My computer crashed and when I try to diagnostic the problem with the TechAID diagnostic Card of Soyo, it tells me that FF is not functioning. After that I bougt a new processor for socket 775 and I turned...
Feb 14, 2014 | Asrock Computers & Internet
No display (black screen)when i put a radeon hd 5450 (pcie 2.1) on asrock conroe 945pl-GLAN how can this be solved?
I was swapping graphics cards and i had the same problem. I just had to be persistent. I had to try booting up i heard some error beeps. I waited 5 minutes to give the bios time to update i rebooted two or three times more before it worked
Nov 26, 2013 | Asrock ConRoe945PL-GLAN (4711140874418)...
Cant install sound driver
Check this Link to download the Audio Drive.
http://www.asrock.com/mb/download.asp?Model=P4i65GV&s=478
Choose the OS and download the Audio Driver. (It's for free).
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Asrock P4i65GV Motherboard
The drivers of motherboard of asrock cant run
If u want to search drivers urself so go to below link and put ur motherboard model no in srearch box..u will get ur drivers..
If not so give me correct model no. of ur Motherboard..i will give u drivers link
http://www.asrock.com/support/download.asp
if it work RATE me if not pls reply me
thanks
bye
Mar 19, 2009 | Asrock 775i65G Motherboard
Acer monitor does not get signal every time
If anything try updating the video card drivers. That's what it sounds like, or the monitor is going. The next time the monitor fails to start, just unplug from the input and put back in. If it starts you are looking at a bad power booster on the board. You can also try pluging in another monitor or try that monitor on a different machine. This way you can eliminate which is bad. I had flat panels and crt's go on me and they usually start by this symptom. It shouldn't be the BIOS, if it's been working right along, same with the processor, it either works or doesn't, it's a monitor scenario.
Mar 08, 2009 | Asrock K8Upgrade-VM800 Motherboard
Graffics accelerator failure
Hi Carpeteddy,
The ASRock K7VT6 motherboard does not have a intergrated graphics card onboard. So your 1.5V, AGP8X / 4X card needs replaced. It wouldn't hurt to uninstall the AGP's driver software, reboot the system & re-install the software. Check the manufactures web site for updated driver software before replacing it.
Link to ASRock K7VT6 MB: http://www.asrock.com/mb/overview.asp?Model=K7VT6
Here is a link to an XFX 1.5v AGP card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2412161&csid=ITD&body=WARRANTY#tabs
The good part of XFX is its warranted for life!
Good luck Carpeteddy!
Questions?
Mike
Sep 29, 2008 | Asrock K7VT6 (K7VT6 RAID) Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Computers & Internet Logo
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
