Question about HP ENVY 120 Inkjet e-All-in-One
Problem moving display - HP ENVY 120 Inkjet e-All-in-One
I have a Pfaff Creative 1473 and am having problems with needle position.
Hello Eelee
As long as the display indicates the change, the needle will move. The needle is not moving with pressing the needle position button because the needle is too close to the fabric .... if the needle is raise up by turning the fly wheel, it will then move according to the number indicated on the display for needle position.
Please let me know how it goes.
Happy Stitching.
Mar 11, 2017 | PfaFF Sewing Machines
Tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
I need display of 56v samtron monitor
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
Jan 31, 2011 | SAMTRON 55V 15" CRT Monitor
CHANGE THE TIME ON MY PANASONIC 7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Mar 14, 2010 | Panasonic KX-T7453 Corded Phone
Are you able to move or change extensions?
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming.
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
Press the show key (top right arrow)
The display should say hunt groups
Press the next key 2 times(bottom right arrow) .
The display should say Featr Settings
Press the show key (top right arrow) .
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Press the release key when finished
Move sets from their old locations to their new locations
Sep 28, 2009 | NorStar Meridian M7310 Phone
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Mouse, cursor and scrolling problems
HI TRY CHANGING DISPLAY SETTING IF YOU THING IT THE DISPLAY
Dec 03, 2008 | HP Pavilion Media Center a1330n - AMD...
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
My n70 had white display pls help me sir
full charge the set..it might show the display then..but after some hours it might become white again..i am also searching for a solution of this problem!
Sep 03, 2007 | Nokia N70 Cellular Phone
HP ENVY 120 Inkjet e-All-in-One Logo
66 people viewed this question
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
richie46
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
