Question about Singer 7436 - INGENUITY
Tention problems how do I adjust the tension
    Champion:
  • 276 Answers
You have to thread the machine with the presser foot down otherwise tensioner may not work properly
Posted on Mar 01, 2014
How do you adjust tention on the star 10 brother machine
Not much information available regarding your machine. It appears from the photo that the machine quite possibly has automatic tension, meaning the user is unable to adjust it. There could be an adjustment for the bobbin tension, but one would have to see the bobbin case setup to determine that.
Jul 11, 2017 | Brother Sewing Machines
What are the normal tention settings
Tension settings are the upper settings and the bobbin settings.
The top settings are generally started at four and adjusted up or down as needed for a good stitch.
The bobbin stitch is a little more difficult but I've attached a guideline. Usually the bobbin stitch doesn't need readjusted too often unless there is a major difference in thickness of the thread being used.
Sep 25, 2015 | Sewing Machines
I do not know how to adjust the tention on my Kingstar DU4410L sewing machine
check with these sites to see if they have a manual or can tell you about adjusting tensions
sewvacdoctor.com
a1sewingmachines.com
Mar 21, 2014 | Sewing Machines
Bottom tention thread loose
try adjusting the top thread tension up one number till the stitches look normal
Feb 07, 2012 | Singer Inspiration 4212 Mechanical Sewing...
How do you adjust bobbin to the correct tension
to regulate the lower tention,turn small screw on tension spring of bobbin case with small screwdriver.to increase tension turn clockwise very slightly .to decrese tention turn counter clockwise.very slightly
Jul 03, 2010 | Brother XL-5500 Mechanical Sewing Machine
How do i adjust the tention on my 786 overlocker . i haven't got a manual and the tention is not correct. what should i do
Make sure when you thread the machine that the pressure foot is in the up position and the thread go in between the tension discs. I have seen more problems from this not happening than anything else.
I have been repairing these for 25 years
Jun 28, 2009 | PfaFF Sewing Machines
Looping stitches on underside of fabric
Check the bobbin to ensure it is installed correctly. Your bobbin is probably in incorrectly. You shouldn't have to change your tention yet but it is possible. this may sound stupid but the other culprit may be that your forgot to put the foot down. Hope this helps. Let us know. If you found that the tension adjustment did help call your local service center and ask for the in-house tech, ask them where the original # position is when it came from the manufacturer and re-adjust the top tention to that.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Could not adjust both looper thread tention on singer ultralock
When servicing these machines I have found that the cover over the tensioners needs to be removed so you can see if there is more adjusting possible. If its a newer serger you would hold the knob somewhere in the middle (4-5) and adjust the knurled part that goes through it. Many times I have had to rebuild these tensioners as they get dirty and need cleaning and adjusting. It may take many tries until you have it adjusting correctly. But it needs to be done.
Feb 12, 2009 | Singer Sewing Machines
I am having problems with the tention how do i adjust
you need to adjust the bobbin tension!
Dec 08, 2008 | Sewing Machines
Singer 7436 - INGENUITY Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
