Question about Dyson DC25 Vacuum
How do you check belt
How do you remove cover to if belt is broken
  • Dyson Master
  • 18,424 Answers
Here is a video that will give you full instructions for belt chang on dc25
Posted on Feb 13, 2014
Brush roller not turning model nv 105-26. Having trouble removing bottom cover
Most likely the belt is broken. It could be the broken belt wedged causing it to be difficult to remove the bottom cover. Make sure all the screws are removed and gently pry on the bottom cover with a small screwdriver
Oct 02, 2017 | Vacuums
Brush belt on my Mach 7 won't tighten
This is a Hoover? Could be either a broken idler arm lock ,or the V belt is worn out. Check the side of the belt. If it is shiny, the belt is worn out, because there is no longer any "teeth" to the belt.Recommendation on belts is that both should be replaced at least once a year.If the idler arm lock is broken, you will have to remove the cover to gain access. There are seven screws and two click locks to remove, before cover can be removed. The part is less than $1.00,
Apr 05, 2014 | VAX Appliances Vacuums
Beater bar isn't working
Sounds like a broken belt. Unplug it flip it over and look at the bottom there is a cover over the bottom and the beater bars look for screws or levers to remove the cover then replace the belt. it goes around the beater bar and a drive shaft. check HERE for a manual and belts.
Jun 23, 2011 | Hoover Company Wind Tunnel U53019 Upright...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Dirt doesn't make it to cannister ...it used to have the spin around affect now it just sits there but some dirt is leaving floor....it is in the hose..I have cleaned ALL filters ...YUCK......help
You have a broken belt. Turn the vacuum over and remove cover plate. You will probably find a broken rubber belt. Buy a new belt for your vacuum. Remove the brush , install the new belt with the brush. Put cover plate back on. You are ready to go!
Jim
Jun 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Can't get the vaccum cover off to see if there is a broken belt.
IF it is a standard style vacuum, then there will normally be between 5 and 7 screws that need to be removed, the the cover can be pried off (usually by depressing 2 locking tabs
I did not read theentire problem because it wasn't allowing me to read the whole complaint so I presume you are trying to replace a broken belt?
May 17, 2009 | Kenmore Vacuums
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Broken vacuum
check the belt it may have broke or stretched out
Dec 31, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Dyson DC25 Vacuum Logo
74 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
