Question about Proform 730 Folding Treadmill Model PFTL71104 - !
Proform 730 SI Error E2 motor will not turn belt
When i try to increase speed the motor makes a slight noise but does not turn the belt. E2
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 75 Answers
SOURCE: The drive motor makes a noise which is louder at higher speeds
Bearing in the motor are bad. Replace your motor.
Posted on Jul 18, 2009
  • 103 Answers
SOURCE: Proform 400GI Treadmill making a very loud noise,
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Posted on May 18, 2010
  • 218 Answers
SOURCE: Clicking sound coming from front
bad bearing in the front roller
Posted on Aug 12, 2010
Why would my belt on the Proform 730 si begin to run backwards? Does anyone know the fix for this issue?
If it was running in the proper direction before suddenly changing the direction then the motor control board is faulty. If it was happened after some service inside then the connection of the motor is reversed unknowingly. If so reverse the connection of the motor. As its a DC motor it will change the direction when the applied DC voltage reversed.
Ajin
Nov 03, 2012 | Proform Exercise & Fitness
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 warning light. tried reset no luck
This conditions indicates that speed pickup signal was lost continuosly for longer
more than 1 seg, after the motor successfully started.Indicate that failure in the
speed pickup or and abrupt belt stoppage,due to any motor, wiring, or motor controller failure.
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
Aug 17, 2011 | Proform 730 Folding Treadmill Model...
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
My ProForm 750 only runs at low speed. Varying
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
Good luck.
Jul 25, 2010 | Proform iLog 750 Treadmill
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Apr 14, 2009 | Proform CrossTrainer Treadmill
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
