Jvc mx s20
NO suena la radio (ni am ni fm). El CD y las 2 cassetteras, funcionan bien.Gracias
silly girl
  • 513 Answers
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Posted on Jan 24, 2006
SOURCE: No sale driver en la lista
Hola!
Se puede descargar el driver de algún lado? No aparece en la lista de controladores disponibles en el equipo. Mil gracias
Anton F.
Posted on Oct 07, 2008
  • 1121 Answers
SOURCE: ya cambie el q401 trabaja bien , pero si lo pago se quema q401
Fonte Avariada, Verifica Condensadores da Fonte
Posted on Oct 30, 2009
SOURCE: no enciende el display queda
mi laptop cuando estoy trabajando se queda la pantalla de muchos colores y me impide seguir trabajando, y tambien sino pasa eso se queda pegada
Posted on Sep 06, 2010
SOURCE: I just purchased a used JVC MX-C33 stereo and the
I have a used JVC MX-C33 and put the cartridge in with only one cd and only one tray in the cartridge. Now it wont eject nor will the single slot open. Any suggestions on how to open it? Thanks, Monte
Posted on Sep 07, 2010
No estoy recibiendo las llamada ni puedo llamar tampoco
Entonces, quelge el telephono. Ponga la handset en la cradle y espere hasta que el tono ya no suena. Estos computadores no sirven bien.
Mar 03, 2014 | Computers & Internet
Reluz interior no prende con puerta abierta
reviso el switch que esta junto a la luz interior?, regularmente tiene tres posiciones, una es para mantenerla encendida, otra es para que encienda cuando se abra la puerta, y la ultima es para mantenerla apagada todo el tiemo
Jun 22, 2012 | 2003 GMC Savana
Trying to change colour cartridge but comes up with message " Remove and check colour cartridge"
ok les cuento nuevamente tengo una impresora Hp photosmart C4180 all-in-one le instale el cartucho negro y el de color recargado o bien generico y me derramo por todas partes tinta incluyendo las tarjetas el problema que me esta dando es que no me enciede la pantalla ni mueve el carro donde van los cartuchos de tinta quesiera saber que puedo hacerle para resolver este problema ya que la desarme por completo la limpie todita y aun persiste el problema. me pueden ayudar por favor , Gracias
Mi correo es Dennisemilianofloresolivares@yahoo.com
Oct 11, 2010 | HP Photosmart 4180 All-in-One Printer
Tengo problema en la fuente conmutada ,no hace ni
ese tipo de televisor viene con mucha soldadura fria. trata de resoldar todas las resistencias y los reguladores si encuentras bien el fusible.el 90% de las veces es eso.
Apr 28, 2010 | Sanyo DS24424 24" TV
No sound from satellite speaker. All cables are continuous (checked with ohm meter). Main speaker works. If I put an ear very close to the satellite, there is a minute amount of sound - but the volume...
Las bocinas funcionan en otra compu?
En la compu donde usas las bocinas funcionan bien otras bocinas o unos audifonos?
Si la PCB está rota, debes de soldar las venas con alambre de cobre, cautín y soldadura.
Prueba las bocinas funcionando abiertas, desarmadas, y revisa si el Circuito integrado se calienta! Prende algún foco led de power?
Mar 10, 2010 | JBL Media 100 Computer Speakers
La tarjeta no me pita y no me da video
Una pregunta, cuando esta conectada la fuente de poder y enciendes el ordenador, el ventilador del procesador se mueve? Si no se mueve quiere decir que hay un problema de corriente.
Esto se puede deber a:
1. los cables/la conexión de encendido no esta bien conectada (eg. Los cables que van del gabinete a la placa madre)
2. La fuente de poder esta pagada, desconecta o defectuosa.
3. La placa madre no esta bien aislada. Es decir la placa madre esta siento “tocada” en sitios donde no debe. Eg. las monturas del gabinete están haciendo contacto fuera del las zonas aislada, o un tornillo/tuerca esta tocando la placa madre fuera de sitio.
Suerte,
Ed
Oct 04, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Jeep Liberty 2002 , se pagan de pronto luces y cepillos parabrisa
revise todas las conexiones a la bateria , los que van a la carroceria o negativos , todos con mucho detalle
Jun 17, 2017 | 2002 Jeep Liberty
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
32 people viewed this question
 Grubhead
Grubhead
